Question about Crosley Kitchen Ranges
Cannot remove oven door to clean
The clip on one side comes out, while the other one will no
  • Debbie Mccrea
    Debbie Mccrea Apr 22, 2014
    called a repair shop. turns out the the clip on one side was all bent, anyway its now fixed. He says we shouldnt remove the doors to the oven for any reason.
2 Suggested Answers
  • 49142 Answers
SOURCE: wire harness for drivers side door hyundai sonada 2006 how to disconnect to replace door
I suspect that the rubber grommet in the door pillar has to be removed and just inside the car behind the kick plate trim you will find a harness connection that is for all the door electrics.
Posted on Dec 29, 2014
Testimonial: "Thanks Bill for responding to question. The door I plan on putting on car has a plug cap on the outside of it, it is probably on the inside as you suggest, but to me that seems like it would not make sense for easy removal. I send you a couple of pictures, I hope you are still up after I get off work I'll send you a couple of pictures. I have seen on YouTube video's of replace door wire harness but still you have to have a way to connect car chassis harness."
OvenDoor came partly off hinges. One side only.
Most oven doors are made to be removed and on most, the hinges have locking clips which hold the hinge so you can remove the door. Have a close look at the hinge which is still in the door and see if the hinge that came out is the same. You may have to get someone to hold the hinge in place while you refit the door.
Jan 28, 2018 | Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
How to remove oven door. whirlpool
Usually the door dont come off just the front glass comes off for cleaning...there should be two or more screws on the top of the frame of the door when these are removed the glass panel should clip off...you will need to apply some pressure to remove the glass but enough that it starts to bend the door frame...be careful..
Nov 05, 2012 | Ovens
Re-fitting an oven door
1. Open the front door you did
2. Open the clips at the hinge housing (2) on
the right and left hand sides of the front
door by lifting them up. you did
Hold the door onboth sides and then close the door and lift
the door up to remove it. assume this is what you did. Refitting is the reversal of removal.
Jan 20, 2018 | Ovens
Can't put the door back on VIKING oven
should be a clip on each side of the door. hold them in as you slide the door back on.
Jun 07, 2009 | Viking VESO105 Electric Single Oven
Oven door
Hi thanks for the question. lay the door on the floor .the hinge must be locked before it can be installed back in the oven. each hinge has a locking clip . push down on the hinge and lock with clip . same on the other side. install door. push door down. unlock the clips. close door. to remove door. push door down. lock clips . pull oven door out . thanks the appliance doc
Aug 05, 2008 | Frigidaire FEF366 Electric Kitchen Range
Oven door
Hi you need to unhook the two clips at the side of the oven hinge. you only hook them on to remove the door.
Feb 18, 2008 | Ovens
Jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Apr 16, 2007 | Neff H7871A2GB 800 Watts Convection /...
Kitchen Ranges Logo
19 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
