Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have a RCA big screen tv (model # rca m50wh72s). I accidentally dropped water on the back on the slot that says "cable card slot" on top of the mother board. Now I can't turn on the tv. The fuse is fine, but wondering what I can do to fix this problem and get the tv to work? Thank sin advance!
  • 585 Answers
Unplug it and allow to dry. It's important that it be unplugged so long as any wetness is present as you can cause further damage. You might use a fan to speed the drying. After the TV is dry you can reconnect to power and try it. If no luck, unplug it and give it some more time. Without the aid of alcohol and compressed air, it can take two days or more to dry the water from under some of the parts. Be patient! or call a servicer.
Posted on Jun 22, 2009
RCA M50wh72s keep blowing lamp
do not touch the lamp during install and if somehow it did touch your skin, you have to cleanit with oilf free napkin and alcohol
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Sep 07, 2014 | RCA Premier M50wh72s Rear Projection Tv...
We have 52
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA M50WH72S Replaced bulb and ballast. TV comes on with good video for about 5 seconds, then off with good audio, front power light blinks 5 times. After a few minutes the video comes back on and repeats...
Check capacitors cp624, cp647 1000uf@35v each. They are in the power supply. Can be seen with bulge on the top. Seems to be a common problem with this model RCA.
Jun 07, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I need a new screen protector for my older RCA big screen TV
I have a screen protector from a 1998 RCA older model big box style tv
Mar 15, 2010 | RCA P56930BL 56" Rear Projection...
No picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
May 31, 2009 | RCA M50WH185 Television
Need color wheel
Unfortunately, the color wheel for this model has been discontinued by the manufacturer. So you would have to check every distributor to see if they have any left in stock. Part # is 271917. Here's a link so you can see this part's current NLA status and get an idea of pricing:
RCA M50WH72S Replacement Part Color Wheel
Jan 25, 2009 | Televison & Video
Problem with rca big screen
possible balast problem it fires the lamp assy.you should hear a high voltage hiss when firing up from a dead stop,unplug and listen when you fire it up again.
Apr 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Online guide to RCA M50WH72S Television
i do not know what happened to my RCA model # M50WH72S
i woke up and went to turn it on and the power was already on and the screen is black and no sound. and the television wont turn off with remote or from front of t.v i have to unplug it. same thing once i plug it back in the t.v power button is on and no picture or sound and wont turn off does anyone know if i need to replace a part ? and where i could find it i dont wanna pay a lot to have someone look at it. i checked the bulb and its in good shape. please help.
Oct 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
163 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
