Question about Sceptre MNTR SCPE|LCD19' 8MS DVI X9WG-NagaV Monitor
Can I connect VGA to DVI-D, not DVI-I? - Sceptre MNTR SCPE|LCD19' 8MS DVI X9WG-NagaV Monitor
    Problem Solver:
  • 10 Answers
There are DVI-D to VGA and VGA to DVI-D converters. If you have a digital DVI PC and want to connect to a VGA monitor you will need a DVI-D to VGA Converter. If you have a VGA PC and want to connect to a DVI-D monitor you will need a VGA to DVI-D converter. I would check KVMSwitchTech as they offer a wide range of video converters.
Posted on Oct 28, 2014
  • 4 Answers
There is a DVI-D single link adapter which would prevent the dual monitor set up. Reference the link in the previous message, scroll to approximately the middle of the first page and verify which type of adapter you have. Good Luck!!
Posted on Apr 23, 2014
  • Sceptre Master
  • 3,320 Answers
VGA to DVI Google Search
Google is your friend.
How do i connect the lcd to my computer
The monitor appears to be DVI capable, (White connector with a grid pattern). You will need to connect the monitor to the computer using a DVI cable (White connector with grid pattern and plus sign shape on one side). If your computer is not capable of connecting to a DVI monitor check to see if the monitor has a Blue VGA (Blue Zig Zag Openings) and connect it with a VGA cable. If your monitor only has the white DVI connector and your computer only has a Blue VGA connector you will need to go to the store (Best Buy, Walmart, Etc) to buy a small adapter that will convert DVI to VGA. If you ask someone for a DVI to VGA adapter they will know what you are talking about. I hope this helps.
Mar 14, 2011 | Sceptre MNTR SCPE|LCD19' 8MS DVI...
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Hi there basically I have two ports on my monitor dvi and vga and dvi is connected with another appliance so that leaves me vga but when I connect my vga to my desktop the computer is on but there is no...
try with DVI port and see it works or not.
if worked buy a converting port (DVI to vga) and connect you video card Via DVI
and connect your other appliance Via VGA port by that converter.
Jan 09, 2011 | Computers & Internet
How to connect my computer to my tv
First off your TV needs a VGA or a DVI connection
there are two types 1. a stand alone TV ( no monitor )
and your regular TV the same VGA or DVI cable used
for your computers monitor is the same cable you'd use
for a TV , it either goes on your video cards VGA or DVI
or on your motherboards VGA or DVI
Jan 28, 2010 | Computers & Internet
How do I connect my Sony viao to my philips LCD
If your PC has a DVI port( ihope u have one) purchase a DVI cable and connect it to your TVs DVI port
DVI port
dvi cable
If your tv has no DVI port and only VGA port buy a vga cable and dvi to vga converter and connect to pc and use it
vga cable
you can also get a svideo to avi converter cable and use it to connect to your tv
svideo converter
Nov 27, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
Sep 02, 2009 | Dell Dimension 3100 PC Desktop
Running two external monitors
Okay. Thanks for the info too...
I looked at the user's guide for this laptop and see exactly what you're saying.
I found it here: http://manuals.info.apple.com/en/MacBook_Pro_Users_Guide.pdf
So, the laptop comes with a DVI to VGA adapter because the only port on this system that will allow you to connect an external display is one that connects to a DVI port (in short, you don't have a VGA port).
moz-screenshot-3.jpgmoz-screenshot-4.jpgOkay, you have a couple of options here:
  1. You can purchase a docking station which, depending on where you buy it from, will be more expensive than the other options. If you decide to purchase one, first make sure that it will provide the ports that you need. For example, my docking station has one DVI port and one VGA port. If and when I connect a second monitor, I will connect it to the DVI port using a single DVI to VGA adapter (as I don't have any flat panels that connect directly to a DVI port). 63efdf2.jpg If you purchase the docking station, make sure it has both the DVI and VGA or you're stilling floating up the same creek without a paddle.
2. You can't use the cable that came with the laptop because it only connects to the DVI port
of your laptop with one VGA connector on the other end, therefore, supporting only one
external monitor. You need either a DVI to DVI and VGA adapter or a DVI to VGA and VGA
adapter
This is a DVI to DVI and VGA adapter
This is a DVI to VGA and VGA adapter
Okay, now that we covered that information, let's get down to business...
Since you already have your monitors and probably don't want to spend $200-300 on a docking station, this is the best and quickest solution:
You have two monitors both with VGA connectors. Your laptop has 1 DVI port on its side (correct?).
Look at the image of the DVI to VGA and VGA adapter. You need to purchase one of these. It will allow you to connect one end to the DVI port on the laptop and connect your monitors to the two VGA ports on the other end...viola!!
You can use the DVI to VGA and DVI adapter but it would complicate your situation unless you were trying to connect a VGA and DVI monitor so we can eliminate that option unless you are desparate and that's the only adapter you find to purchase.
These adapters are very inexpensive (probably anywhere from $9 to $19. You should be able to purchase them at a store that sells computers, hardware, software, etc. You may even find them at Wal-Mart or RadioShack. If need be, you can purchase one online. However, if you go out and search a couple of stores or computer places, you should find one and be able to connect your monitors when you get home.
Feel free to leave any comments if you need further information.
Thanks for using Fixya and don't forget to rate this solution.
Apr 03, 2009 | Apple MacBook Pro Notebook
WANT TO HOOK MY COMPUTER TO MY TV? COMPUTER : T6534 EMACHINE TV SET : MAGNAVOX WHAT ITEMS DO I NEED?
You Need a VGA to DVI Connector and a dvi cable which connect at the back of the tv.
you need to connect the VGA Port(Blue Colour) with VGA to DVI connector and then Connect DVI cable and Connect your computer.
Jul 14, 2008 | Computers & Internet
VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Feb 24, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Computers & Internet Logo
123 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
