Question about Infinity 1020W Car Subwoofer
I have two 12" kicker cvrs and a kicker zx 300.1 amp....depending on how loud i turn the radio up the amp blows the fuses....
  • Frank Fulton
    Frank Fulton May 11, 2010
    Has it done this since you installed it, or was it working fine for a while and this just happened? what kind of amp wiring? what kind of ground? what type of enclosure? Fill in the blanks and I can definately help you figure this out
Kicker amp 350.4 blows fuses
Check your wiring for any exposed. Make sure there are no wires touching and that you have the proper gauge wiring for that size amp. I used 4 gauge with that same amp and never had an issue.
May 20, 2016 | Kicker ZX-350.4 Car Audio Amplifier
I have a Kenwood 720 amp powering 2 12 inch kicker cvrs..the amp will work fine for a few second then the bass starts skipping out and the amp shuts off..
check speakers impedance are matching amps. example: if you drive a 4 ohm amp with lower imp you are close to blow your amp or it goes to protect itself from you. anyway your amp provides 140watts maximum on 4ohm in bridged mode, so if you connect two 12" kickers with 4ohm, they will have 2ohm in parallel connection. solution would be to connect them in row (serial) but impedance will go up to 8ohms then.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 26, 2011 | Kenwood Car Audio & Video
No power to my kicker ZX 1000.1
sounds like you blew a fuse for the battery power supply to the amplifier
Mar 23, 2010 | Kicker ZX10001 Car Audio Amplifier
I have two kicker cvrs 2003 model wired at a 2 ohm load, one
Sounds like the sub is blown. Swap the two subs and see if the sound comes from the other sub in the original location as well. If not, then you have a bad sub. If the bad sound happens with both subs then you need to look at wiring and the Amp.
Mar 07, 2010 | Kicker CVR12 Car Subwoofer
One of my kicker cvrs rattle really loud at high volumes
It could be the foam edging where the speaker meets the edge of the cone. Rubber works better than foam, and I believe kicker uses foam for this model. Check for any missing screws because sometimes air leaks make that sound you hear. also try turning down the amp a little bit
One of my kicker comp cvrs
Blown sub, or air leaks in the box.
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Mono amp
well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
Sep 26, 2008 | Kicker CVR12 Car Subwoofer
Infinity 1020W Car Subwoofer Logo
43 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
