My TV turns itself off after 5 seconds No audio The sound of picture tube starting is not there
    Top Expert:
  • Televison & ... Master
  • 36,324 Answers
Could be power supply failure
Posted on Apr 22, 2014
4 Suggested Answers
  • 163 Answers
SOURCE: TV has green sceen and turns off by itself
dont do nothing with that tv go and buy a new one and thats all...good luck
Posted on Aug 07, 2006
techman
  • 3130 Answers
SOURCE: TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Posted on Sep 14, 2006
Valiis
  • 72 Answers
SOURCE: jvc 24" widescreen tv problem turning on
The tube is not blown or the Tv would not turn on at all. I would say its probably a bad cable or the board that the cables connect to the back of the Tv with is either loose or bad. Try replacing the cables first, then try holding the cables very snuggly in place and seeing if that gives a solid signal for more than 15 seconds. If that doesn't do it, you probably have a bad input card. You would need to have the TV serviced or get a new TV
Posted on Aug 26, 2007
Loud sound of air and screeching tv keeps powering down
Sounds like a CRT is arching internally. to confirm remove the covers to have a view of the picture tube necks- in adimly lit room you should see bue arching in one of the tubes. (there are three piture tube with glass necks)
Sep 14, 2009 | Zenith R56W36 56" Rear Projection...
Toshiba televison picture keeps going yellow
Sounds like the blue is disappearing from your picture. A common cause of this is bad solder connections which can cause the blue signal to be lost at several places. It could also be due to picture tube failure. Sadly, I'm leaning toward tube failure because of your description. Bad solder connections usually take some time to start acting up after you turn on the set, but you say this happens every time within a few seconds. This is typical of a picture tube failure where an internal connection is okay until the tube heats up, and that takes only a short time. A service shop could check the set to make a firm diagnosis, but if the tube is the culprit you should replace the TV. It's not economical to consider tube replacement.
Apr 08, 2009 | Toshiba Televison & Video
RCA D52W20 - turns on and off, blue screen, tech said need picture tube
It does sound like the tube, have the shop use a tube restoration machine to rejuvinate the tube, and replace the eprom to try to correct the no power down situation.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
It very well could be the Blue CRT shorting out. However the not shutting off is not a symptom of the tube being shorted that sounds more like a signal board issue rather than a picture tube, as the signal board can cause all the symptoms you have described.
Aug 26, 2008 | Televison & Video
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Sep 13, 2006 | GE 32GT740 32" TV
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
