Question about Sony VPL-ES7 LCD Projector
How do i get my pictures projected to wthe white screen
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
Tv picture sags
Projection tvs have a white colored cloth drapped over the pastic screen on the inside for the image to be projected on. This white film may have become unattached on the insid causing the sag.
Jul 27, 2009 | Televison & Video
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
White halo fuzzes the picture on TV
Had the same problem with white glows. Followed the directions in this link and the white glows and color brilliance was fixed.
http://www.avsforum.com/avs-vb/showthread.php?t=1148792
Apr 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
Problem turn on picture few sec. no picture only clear white and sound
I had this problem and replaced the bulb. I have not had the problem since.
Nov 22, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
No picture white screen
check you bulb and your color wheel notorious on this set
Nov 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Picture flashes and soft images
sounds like poor regulation replace regulator get back too me
Oct 13, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony VPL-ES7 LCD Projector Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
