Question about Whirlpool Duet GHW9150P Front Load Washer
I show an F 25 code on my whirlpool duet washer and it does not spin. It is not even 3 years old. Thank you.
  • 15,935 Answers
F25 is a motor tachometer code.
In simple terms, the machine control does not know how fast the motor is turning so it shuts down.
The problem could be in the motor, motor controller, the main control, or a wiring harness problem.
Since it is newer, I expect it is something simple like a connector that is not plugged in properly, or has vibrated loose from uneven load. I am seeing a lot of this kind of problem lately.
If you can't wait for service, unplug the machine and remove the lower front cover and check the connections at the motor and motor controller. You can remove the top and check the connections at the main control. Just be sure not to change anything, just make sure all the plugs are pushed in to the connectors properly.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 20, 2009
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
3 year old Whirlpool Duet - F07 error showing up 98% of the time on high spin; 70% of time on medium & low spin. Checked conections between MCU & CCU. Should I buy a new MCU or a new washer?
No do the following:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
If the wiring is definitely OK and the drive motor is OK then the MCU is most likely to be the culprit.
Dec 30, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
113 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
