Question about LG GH22NS70 Super Multi Disk drive DVD RW DVDRAM 22x22x12x IDE internal 52 Burner
My lg gh22ns70 supermulti disc drive dvd player is neither reading dvd or cd...My dvd driver software is up to date...
  • 51 Answers
SOURCE: dvd not reading
Clean your lens with lens cleaner cd and then try it.....
Posted on May 20, 2009
joecoolvette
  • 5660 Answers
SOURCE: LG GH22NS70 Super multi DVD Rewriter just used
Power cable attached, interface cable attached, (Dta cable), and the small audio cable attached, plus computer on, and Windows loaded.
Windows XP:
1) Click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) When Device Manager loads, left-click on the + sign to the left of - DVD/CD-ROM drives
7) Right-click on the name of the optical drive.
8) Left-click on Uninstall
A Microsoft 'squawk box' will come up,
"Warning you are about to uninstall this device"
It's okay. Click on OK.
Close all windows, go back to your desktop screen.
Turn the computer off normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute. Turn the computer back on.
You should get a pop-up out of the system tray, "Found new hardware", and perhaps another one will follow, "Found XXXX DVD drive"
No? Doesn't work?
Try using another 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The IDE harddrive shown, is just an example of a device that uses a 4-pin standard Peripheral power cable. Mistakenly referred to as a 'Molex' power cable)
Make sure the interface cable (Data cable) is plugged in tightly.
Regards,
joecoolvette
Posted on Jul 17, 2011
bronk50
  • 27725 Answers
SOURCE: I recently had a problem relating to
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
if your computer came with a motherboard disk the drivers could be on it or you will need to download one
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
if this driver package is not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don
Posted on Sep 14, 2011
ratheeshmoha
  • 349 Answers
SOURCE: my lg supermulti dvd writer are not reading a cd
Sir
Change DVD Drive
Posted on Oct 08, 2011
littlejose
  • 40 Answers
SOURCE: lg hl-dt-st dvd ram gh22ns70 after use alcohole 120% does not recognize dvd only cd
Uninstall Alcohol and see if it is an issue specifically with that program. It may not be compatible. You made need to update the firmware on the bios r the dvd firmware. You may also need to replace the entire DVD burner.
Posted on Oct 18, 2012
Download dvd driver
Go to Computer => System => Device Drivers, select the drive from the list, right click it and choose Update Driver.
Sep 19, 2013 | LG GH22NS70 Super Multi 22X SATA DVD...
Lg hl-dt-st dvd ram gh22ns70 after use alcohole 120% does not recognize dvd only cd
Oct 18, 2012 | LG GH22NS70 Super Multi Disk drive DVD RW...
Driver download
Here is LG's support page for your product. Register the drive, once you've registered the product you can request free support in resolving your issue with LG. There doesn't seem to be a driver available for the product which leads me to believe you don't need any additional software to make it work!
Jan 19, 2012 | LG GH22NS70 Super Multi 22X SATA DVD...
Windows XP:
1) Click on Start
No? Doesn't work?
Regards,
joecoolvette
Jul 17, 2011 | LG GH22NS70 Super Multi 22X SATA DVD...
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
Dvd not reading
May 20, 2009 | LG SecurDisc 20x Internal Double-Layer DVD...
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
LG MODEL NUMBER GSA-H42N 18X SUPERMULTI DVD BURNER NOT ABLE TO WRITE ON SONY DVD-RW DISC
in window under my computer is your DVD writer shown as DVD-RAM drive, if not then re-instal the drivers for your DVD.
If its installed as DVD-RAM then right click the DVD-RAM icon in the my computer and choose properties, under the recording tab select enable recording, try burning a cd using the windows xp based roxio by sending your files to the DVD-ROM.
If it burn a CD this way then all you neec to do is use a different CD burning application software.
Oct 22, 2007 | LG GSA-H42N 18x DVD RW DL IDE Drive...
LG GH22NS70 Super Multi Disk drive DVD RW DVDRAM 22x22x12x IDE internal 52 Burner Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
