Question about KitchenAid KFCS22EVMS Stainless Steel Compact Wine Cooler Side by Side Bottom Freezer French Door
Clicking damper The air damper at the top rear of the refrigerator size clicks for about 20 seconds every so often. If I remove the cover, the clicking stops. How do I stop the clicking or is it easy to replace that entire damper assembly?
4 Suggested Answers
  • 50 Answers
SOURCE: I have a KSRS27GWH02 side by side refrigerator, freezer out
Take the make, model number, and serial number to an appliance parts dealer, Explain to them, where and what this switch is doing. They should be able to provide you with a solution or part. A white switch, located behind a box? It would be inside a cover, attached to the compressor. That would be a relay. If you decide to remove it, unplug the box. Remember where the wires go. Take it with you. Good luck.
Posted on Jul 13, 2009
  • 2468 Answers
SOURCE: Refrigerator not cooling, freezer not
the buzzing and click noise is the ptc overload relay on the compressor,its bad,unplug it off the compressor and obtain a replacement and plug in the new one
Posted on Mar 24, 2011
imufo2
  • 3773 Answers
SOURCE: Refrigerator stopped cooling. The
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 03, 2011
Where is damper door in a kenmore refrigerator model #9510681 side by side
If you can't see the damper door, it is most probably shut, possibly frozen or not working. Top of middle section, allows airflow from freezer to fridge part. Switch thermostat off, wait 20 mins, switch back on. If damper doesn't open, check stat and damper motor.
May 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer is running and cold, the refrigerator seems to be getting warmer like as if the cold isn't transferring. Is there a fan suppose to be running or what?
It is quite common for a refrigerator to begin the first signs of a defrost problems once he fresh Food section begins to warm. Auto Dampers are an additional component to check while searching for the true reason for Fresh Food compartment warming. First look inside the freezer compartment and and see if there is a layer of frost building on the rear wall. If yes you will need to manually defrost unless you have anothr place to store the freezer goods. Unplug refrigerator and then remove the rear panel of freezer to get a good look at the snow covering your evaporator coils. Defrost with a hair drier. Now we need to look for the cause Auto Damper, Click here for the photo location of these parts=> MSD2756GEW Controls Section the adaptive defrost control is most likely the problem and is listed in the photo as location 13 and the auto damper
61005971 Damper Control Assembly
61005988 Adaptive Defrost Assembly
The Auto Damper model refrigerator has two controls and both have capillary sensing.
The Auto Damper controls the fresh food temperature and the Freezer Temperature
Control guides the freezer temperature. The fresh food compartment temperature is maintained by a damper assembly located at the back of the temperature control housing. Changes in air temperature cause the damper door to open and close. A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the coldest position increases the flow of freezer air into the fresh food section. The freezer compartment temperature control warms at a faster rate and cools at a slower rate, increasing the compressor run time necessary to maintain a satisfied freezer temperature control.
Click Here=> Here is how to test a Maytag MSD2756GEW Auto Damper
There is always other possiilities but I see two other things that may cause this and that is the defrost heater with defrost Thermostat=> 61006199 Defrost Heater Assembly
I know this was long and possibly confusing but please ask if you should have questions or one on one assistance, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MSD2756G Side by Side Refrigerator
The refrigerator seems to be losing its cooling, while the freezer remains freezing.
Hello, One of the first things that you would check would be the evaporator fan motor inside the freezer. If you open the freezer door and can hear the fan working and pushing air then you can surmize that the fan is not the issue at hand. If the fan were not working then you would have to remove the rear panel on the rear wall of the freezer which would give you access to the evaporator coil as well as the evaporator fan. If you do not hear the fan and take the rear panel off and find an ice build up on the evaporator coil this would be termed a defrost issue and if you do find ice then message me back and I shall instruct which parts to test and how to test them. Now moving on that you have assured the fan is working. You would next look at the diffuser door located on the inside of the refrigerator towards the rear on the middle partition. The door is also called a damper door and if you click this link http://c.searspartsdirect.com/lis_png/PLDM/M0312532-00002.png it is noted as part number 11 in the diagram you also have a tempreture control noted as part number 3 and an adaptive defrost at part number 13. You would remove the damper door and assure that it was able to function as to open and closeing and that there was no frost build up on the door itself if there was it is best to replace the damper door. If the damper door were functioning properly you would next look at the tempreture control which if you can hear the control make the click sound from the on to the off position it would usually suggest that the control is working properly. If you have any further questions message me back. If you do have the air flowing in the freezer area I would then look at the damper door area as to your problem area in your machine. Thanks Rick
Sep 03, 2011 | Jenn-Air JCD2389G Side by Side...
How do I remover the damper cover from my French door, bottom freezer Maytag refrigerator? The damper has gone out twice. It takes the repairman exactly 30 seconds to take off the cover and change the...
Hello, Thank You for using FixYa. I will be helping you today. The vent or grille part just pops out and behind it are two screws remove the two screws now you can remove the cover. The damper is just held on by a clip an each side. Here is the part Control, Damper Part #: 67003903
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Maytag MFD2560HES Bottom Freezer French...
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have a Kenmore refrigerator/freezer model # 596.65232401, this is the one with the freezer on the bottom and refrigerator on top. The freezer works fine, the refrigerator was not cooling, I removed the...
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Nov 27, 2010 | Kenmore Refrigerators
How do I get the rear driver side shock strut off of a 2003 Hinds Civic EX?
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Raise and support the vehicle safely. Remove the rear tires.
  3. Remove the flange bolt from the bottom of the damper.
  4. Remove the flange nuts from the bottom of the damper.
  5. Open the trunk and remove the access panel cover, if necessary.
  6. Remove the flange nuts from the top of the damper
  7. Remove the damper assembly from the vehicle.
    Exploded view of the rear suspension strut-2001-05 Civic
    Click to Enlarge
To install:
  1. Position the damper assembly in the vehicle.
    NOTE
    Be aware of the direction of the damper mounting base so that the small hole dot on it is toward the front inside of the vehicle,
  2. Loosely install the flange nuts on the top of the damper.
  3. Loosely install the flange bolt on the bottom of the damper.
  4. Raise the suspension with a floor jack to load it with the vehicles weight before tightening the nuts and bolt.
  5. Continue the installation in the reverse order of the removal procedure.
Nov 17, 2010 | 2003 Honda Civic
Warm Fridge No Airflow...Control Panel Beeping
i just had the same call today i ordered the damper control because it seems at times more air comes in and than at time like 30 seconds later nothing and the fan is working its not mine fridge but what you can do take the freezer side upper shells off the ice maker on(not necessery but i thought it was easier) and take off the little cover which is covering the damper it has two screws and look inside of the opening and you'll see a damper, turn up the fridge and see if the damper moves and you can turn down the fridge and see if the damper is moving if not you need a damper! good luck
May 20, 2009 | KitchenAid KSSC42FMS Side by Side...
Maytag MSD2657HES Refrigerator Side by Side
The air that cools the refrigerator section comes from the freezer. The refrigerator temperature control controls the run cycle. You may have to replace or have the thermostat replaced. The temperature control has failed.
Jul 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Amana Mod # ABB2223DEB Refrigerator
Try damper part number W10167268 from Whirlpool. They re-engineered the part, it's works different. Whirlpool issued a bulletin to servicers, but won't cover it under warranty (I have tried for many customers) "A bulletin is NOT a recall"
Jun 03, 2008 | Refrigerators
KitchenAid KFCS22EVMS Stainless Steel  Compact Wine Cooler Side by Side Bottom Freezer French Door Logo
47 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
