Question about Hobart 1HF50D Deep Fryer
Services manaul can we get a services manual and part list for this Hobart 1HF50D Deep Fryer we work on board ship at sea.
  • 640 Answers
Re: services manaul
Just to give a little more info,the link kstfas gave you is the operation and installation manuals with a little troubleshooting ideas.hobart does not give out their service manuals.however you can get a parts manual.hope this helps
Posted on Nov 04, 2007
  • 75 Answers
Re: services manaul
Hobart has these available on line. It may take a little searching and a while to download but follow this link and the manuals are there. Please rate this solution as solved. If you need any more help make a note on here and I will work with you.
Posted on Nov 03, 2007
0 characters
3 Points
My 1.5 Liter Deep Fryer did not come with an instruction booklet. Can I please be sent one or are the instructions on a site?
Go to this page:
Enter your model number and download the manual in th right column where it says manual.
The model number I listed is for the 2 qt fryer. You will need to enter your model number on the left side at center page to bring up your manual.
I tried using Model number F1045 which should be the 1.5 liter model and it says not found. You can call them here:
Thanks for choosing FixYa.
Sep 07, 2010 | Euro-Pro Deep Fryers
On starting, pilot flame will not stay lit to switch on.
sounds like you need to replace the thermopile, which would make this a milli-volt system
Jun 29, 2010 | Hobart 1H50D Deep Fryer
Most likely solution is to replace the reset. If the new reset trips, check the amperage on the elements. At 208V all three phases should be around 47A, 480V around 20A each. Check all wiring connectors for good connections and no evidence of corrosion or overheating.
Feb 25, 2010 | Hobart 1HF50D Deep Fryer
How to set temperature on a hobart electric gas fryer
You can download operation, parts & programming guides from hobarts website. You will need a model# serial # and the ML# from the unit.
Jul 02, 2009 | Hobart 1HF85C-2 Deep Fryer
Label says propane, needs to run on natural gas.
You need to change the gas valve,burner orfices,pilot and maybe a gas regulator.I service these fryers often as im a hobart tech.Goto,type in your model and the parts list.Any ? let me know.
May 06, 2009 | Vulcan EF3 Deep Fryer
Goto,type in your model and you will be able to download a user manual.
Apr 20, 2009 | Hobart 1HF50D Deep Fryer
I have a ck20 hobart deep fryer that when plugged in and turned on, lights both lights,but does not heat.I checked both fuses with an ohm meter and they appear to be fine.Can you tell me what the...
The element will show infinite resistence if defective. Overload switch.....Do you mean High Limit T/Stat? Use your ohm meter across terminals- should read closed circuit...0 ohms. If not, push red reset button...if clicks once, is now reset and contactors will close and unit will heat. If always clicks, replace limit t/stat Like wise, check themostat--should click once for heat demand and check cicuit same as limit t/stat. May have wire burned off terminal connector at element.
Mar 30, 2009 | Hobart 1HF50D Deep Fryer
Hobart Model#GF035A
The thermostat is acting up,The t-stat controls the heat,did you replace the pilot valve or gas valve?If there is 1 valve make sure the wires are in the correct terminals.
Sep 03, 2008 | Hobart 1HF50D Deep Fryer
Hobart 1HF50D Deep Fryer Logo
725 people viewed this question
Top Hobart Deep Fryers Experts
Richard Lilja
Richard Lilja
Are you a Hobart Deep Fryer Expert? Answer questions, earn points and help others
