Question about Dryers
Dryer blowing thermal fuse - Dryers
    New Friend:
    Problem Solver:
  • 11 Answers
Blowing thermal fuse means it's getting too hot. Almost always due to blockage. Thoroughly clean ductwork and dryer. You will have to partially disassemble dryer to clean blower housing, etc.
Posted on Apr 23, 2014
the dr
  • 447 Answers
SOURCE: Thermal Fuse
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Posted on Nov 19, 2007
  • 126 Answers
SOURCE: how to replace a thermal fuse
on most kenmore dry. it is located behind rear lower panel,either in the center or down by the blower. it is white with 2 wires attached
MAKE SURE THE POWER IS OFF!
Posted on Dec 14, 2007
larryyb
  • 291 Answers
SOURCE: thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Posted on Nov 25, 2008
localwonder
  • 6784 Answers
SOURCE: keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Posted on Mar 09, 2009
vickygomar
  • 460 Answers
SOURCE: blown thermal fuse on Kenmore dryer
I need the serial# to assist you better.
Thank you for trust fixya.com
Posted on May 14, 2009
Kenmore model 110.80754001 doesn't heat but element is good
The problem could be the dryer thermal fuse. It is usually located on the blower housing. If the dryer overheats, the thermal fuse blows to cut off power to the dryer. If the thermal fuse has blown, then generally the dryer won't start. If your dryer drum rotates, but does not heat, then the problem could be something else.
If it is the thermal fuse, it cannot be reset-if the fuse has blown, it needs to be replaced.
If it is the fuse ... it is also important to figure out WHY it blew ... or else the same problem could show up. Sometimes the thermal fuse blow due to a clogged vent. That should be checked.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Kenmore Dryers
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
I have a Kenmore 110.63032102 dryer and I put a pair of sneakers in it. It shut off and now it wont even turn on. What's wrong?
Drying a pair of sneakers causes the dryer to overheat and this causes the thermal fuse to blow. The thermal fuse is wired in series with the motor circuit and if it blows, power to the motor is terminated causing the dryer not to turn on. Disconnect power then Pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to expose the thermal fuse on the blower housing.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Let us know if you need further advice.
Jan 26, 2011 | Kenmore Dryers
Maytag dryer is less than 3 years old. Blew thermal fuse. Cleaned all of the venting inside and out. dryer still overheating and blowing the thermal fuse. Replaced the thermal fuse and the high temp sensor...
Have you tried replacing the operating thermastat it's what shuts it off at the right temp and would cause the thermal fuse to go if it is not shuting.off at the right temp. It happens.
Hope this helps.
Dec 05, 2010 | Maytag PYE2300AY Electric Dryer
My kenmore 70 dryer quit heating but runs like it should, does it have fuses inside the dryer? we have a breaker bos and breaker not tripped.
Thermal Fuse is located inside the dryer, If the thermal fuse gets too hot, it will blow, and completely shut down your dryer until it is replaced. This fuse is often mounted within the exhaust duct in the back panel. It’s about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced. When replacing this fuse, check the dryer vents to make sure there is no lint buildup which can cause the heat to stay trapped and blow the fuse again.
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 01, 2010 | Kenmore Dryers
Thermal fuse keeps blowing
Nov 25, 2008 | Amana ALE331RAW Gas Dryer
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
Top Dryers Experts
