Question about Samsung SCX4824FN Mono All-in-One Laser Printer
Please can you tell me what cause paper jam 1 sometimes on samsung 4824fn
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
Uck under toner cartdige
Posted on Oct 02, 2015
kakee
  • 1269 Answers
SOURCE: I have a Samsung Printer
Despite the paper jan 2 error, can't you already print or not? If not, There are still papers inside the printer, a torn piece which you can't see. Look thoroughly inside the printer. Try to press the Resume and Power button for 15 seconds then release.
Posted on Aug 25, 2008
  • 220 Answers
SOURCE: paper jam 1 - samsung clx 2160n
fuser needs replacing.
Posted on Jul 08, 2009
  • 42 Answers
SOURCE: samsung ML2010 printer; paper jam
Lise, That is VERY similar to what I experienced yesterday. You can probably fix this by cleaning the rollers (all of them) thoroughly. See what I did exactly, and find directions to all the rollers from your manufacturer: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html
Let me know if that helped you as it helped me solve the problem completely.
Posted on Oct 01, 2009
tim30921
  • 6 Answers
SOURCE: Samsung CLP-300 click print and it starts to try
clean the rubber roller that pulls the paper from the tray with alcohol
Posted on Jan 10, 2010
jyvibar
  • 148 Answers
SOURCE: samsung clp 310 printer regularly jams
avoid using paper that is below 50 gsm
Posted on Mar 26, 2010
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
the problem whit this printer is that the fuser unit gear is warn very fast you need to replace the gear or the complete fuser unit. But the best thing to do is get a new printer. i have fixed some of this printer more the 5 times in 2 years whit the same problem
Apr 22, 2014 | Samsung SCX-4824FN A4 Mono Laser Printer
How do I print envelopes in the printer Samsung SCX 4824fn? thanks
• Successful printing on envelopes depends upon the
quality of the envelopes. When selecting envelopes,
consider the following factors:
- Weight: The weight of the envelope paper should
not exceed 90 g/m2 or jamming may occur.
- Construction: Prior to printing, envelopes should
lie flat with less than 6 mm curl, and should not
contain air.
- Condition: Envelopes should not be wrinkled,
nicked, or otherwise damaged.
- Temperature: You should use envelopes that are
compatible with the heat and pressure of the
machine during operation.
• Use only well-constructed envelopes with sharp and
well creased folds.
• Do not use stamped envelopes.
• Do not use envelopes with clasps, snaps, windows,
coated lining, self-adhesive seals, or other synthetic
materials.
• Do not use damaged or poorly made envelopes.
• Be sure the seam at both ends of the envelope
extends all the way to the corner of the envelope.
Envelopes with a peel-off adhesive strip or with
more than one flap that folds over to seal must use
adhesives compatible with the machine's fusing
temperature for 0.1 second. Check your machine's
specification to view the fusing temperature, see
page 82. The extra flaps and strips might cause
wrinkling, creasing, or jams, and may even damage
the fuser.
• For the best print quality, position margins no closer
than 15 mm from the edges of the envelope.
• Avoid printing over the area where the envelope's
seams meet.
Place the side to be printed facing up.
Envelope Preprinted paper Transparency
Punched paper Card stock Letterhead paper
Labe
open the direct paper try on top of your A4 paper try by pushing it!
Apr 22, 2011 | Samsung SCX-4828FN All-In-One Laser...
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
I have a Samsung CLX6210FX. I get this error Paper Jam 2 Check Inside. I check the paper tray and the toner door but could not find where the paper jam is. Please help
This can be very difficult to find especially if they are small pieces. If you remove the toner cartridge and with a flashlight look all around for any evidence of paper. Also check thoroughly all the doors that will open and all around the rollers. Lastly and this is difficult is the fuser in the very back of the printer. These rollers are extremely hot and sometimes when the fuser goes bad, it will keep the paper in the fuser causing the jam. On the menu you will probably see error codes as well. Hope this helps.
Mar 19, 2011 | Samsung CLX-6210FX Laser Printer
Samsung CLP 300 printer jams when using legal size paper. I've changed the paper size in the properties menu and it still jams every time. Help.
Make sure the paper setting in the printer driver software is set correctly. Sometimes that can cause this problem.
Aug 04, 2009 | Samsung CLP 300 Laser Printer
SAMSUNG SCX-4824 PRINTING BUT NOT COPYING
You can reset SCX 4824 through reset software and use refill toner forver.
Jun 02, 2009 | Samsung SCX-4828FN All-In-One Laser...
1 get 3 fuzzy lines on page
If you're getting frequent paper jams, it's usually caused by the feeder motor assembly failing. When the paper is pulled through the printer, if the assembly is failing, it causes the paper to jam and can effect how things are printed. (Sometimes it will go to fast and things will get blurred, sometimes it'll go to slow and text overlaps)
If that sounds like the problem, it's cheaper to replace the printer (can be bought for $50) the it is to repair it ($25 for the motor, $45 for labor to install the motor)
Aug 28, 2008 | Samsung ML 2010 Laser Printer
Printer malfunction
The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
Dec 19, 2007 | Samsung ML-2150 Laser Printer
Samsung SCX4824FN Mono All-in-One Laser Printer Logo
59 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
