Question about AEG Washing Machines
Aeg protex washing machine flashes start/pause button
L87480fl
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Posted on Dec 01, 2008
  • 3230 Answers
SOURCE: AEG Lavamat 86720 washing machine
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
post further comment for more help......
Posted on May 06, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
SOURCE: AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Posted on Feb 01, 2010
Machine not spinning or filling with water - AEG Protex Lavamat
Is it plugged in? Is the water on? Is the door closed?
Jan 18, 2018 | AEG Washing Machines
Have mislaid the manual for AEG Lavatherm protex plus. Where can I find it online? Can't access the model number as machine set in.
User's Manual - AEG Appliances
www.aeg-appliances.ca/wp.../AEG_LAVATHERM-T65179AV-_manual_070913.pdf
LAVATHERM T65179AV Dryer - ... In the AEG webshop, you'll find everything you need to keep all your AEG appliances ... read this user manual carefully, in-.
AEG - Tumble Dryer user manual, operation instructions
www.usersmanualguide.com/aeg/tumble_dryer 4, Lavatherm 310 A; Instruction Manual - Product Number Code:607625125. 5, Lavatherm 310 w; Instruction Manual - Product Number Code:607625014.
[PDF]LAVATHERM 75280AC EN User manual - User Manuals
www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL...pdf LAVATHERM 75280AC. EN User ... Thank you for choosing this AEG product. We have ..... Dry Plus. Extra Quick. Mixed. 3 kg. To dry cotton and synthetic fabrics,.
[PDF]LAVATHERM 76280AC EN User manual - AEG
www.aeg.co.uk/laundry/laundry/dryers/.../downloadpdf/?...User%20Manual... LAVATHERM 76280AC. EN User .... this user manual carefully, including its ..... Dry Plus . The wool drying cycle of this ma- chine has been approved by The.
AEG LAVATHERM 75470AH USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 75470AH View and Download AEG LAVATHERM 75470AH user manual online. ... filter, er filters DISPLAY Symbol On/Off Dry Plus Reverse Plus Anticrease Buzzer Time ...
AEG LAVATHERM 65270AC USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 65270AC View and Download AEG LAVATHERM 65270AC user manual online. LAVATHERM 65270AC Dryer pdf manual download.
User Manuals ' Service & Support ' AEG
www.aegaustralia.com.au/support/manuals/ Search for user manuals for your AEG products online with our finder tool.
manual for AEG Lavatherm protex plus Google Search
Jun 25, 2017 | AEG Dryers
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
Where is the filter on my aeg protex washer dryer
Tumble dryer Lavatherm T75280, 8kg
23988722-wycorcio5u0xxoh2plbhrodj-3-0.jpg 2. Open the filter
23988722-wycorcio5u0xxoh2plbhrodj-3-14.jpg 23988722-wycorcio5u0xxoh2plbhrodj-3-20.jpg Dado
Apr 03, 2014 | AEG T75280AC ProTex Condenser Tumble...
Cycle won't start/start light flashing red
Probably a bad wax motor in the door switch or a bad control board.
Yeah you should call someoneif you're not a learned handyman.
Feb 06, 2014 | AEG Washing Machines
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Mar 24, 2008 | AEG Washing Machines
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
Jan 10, 2008 | AEG Washing Machines
Washing Machines Logo
221 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
