Question about TallyGenicom 2265+ Matrix Printer
+0001 +131 --- 000002-0944-2191
Printer printed half way before the hardware alarm came out
    Problem Solver:
  • 17 Answers
Most likely the timing strip is dirty. The timing strip is right below the carraige bar and looks like a narrow plastic strip. clean this with a mild cleaner (glass cleaner). If this does not fix your problem, the 000002 error is a "horizontal task" error. meaning that either your motor or your main logic board is bad. If you have another printer available, try swapping the logic board to see if the problem follows.
Posted on Apr 22, 2014
Why are there times when it only prints half a page?
Hi Mary,
Try and print a hardware self test on the printer to find out if it is a hardware or software issue. Open this link in a new tab in your browser...
Printing a Network Configuration Page.
If you have a valid IPv4 address for the printer then try and access the Embedded Web Server for the printer.
Type the IP address into your web browser's address bar. (Internet Explorer)
If it loads the printer's network page then the printer is on the network.
Power cycle the router, computer and printer.
Try printing again.
If you don't have a valid IPv4 address, then do the following steps:
Restore the printer defaults.
  1. On the printer control panel, press the Wireless button (). The Wireless menu displays.
  2. Press the button () next to Settings.
  3. Press the Down Arrow () to select Restore Defaults, and then press OK.
  4. Press OK again to confirm your selection.
Sep 22, 2015 | HP ENVY 5530 e-All-in-One with 2-month...
+0001 +131--- 000002+1864+3754
The hardware alarm indicated 00002 is indicating a problem with print head movement. More specifically the error is indicating an error when the Carriage Motor has accelerated.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the print head.
Clean the carriage shaft, and ensure it is free from any form of lubricant.
Clean the timing strip and ensure it is correctly in place.
Mar 17, 2012 | Tally Dot Matrix T2265C Printer
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Nov 18, 2011 | Tally Matrix T2280 Printer
I have a problem with 2280+ tallygencom printer. I have hardware alarm problem and with sense code +0001 +131 --- 000002 +2733 -0962 . Please help me . Thanks
The hardware alarm indicated is indicating a problem with print head movement.
1)The printer ribbon is not jammed and is located correctly in the printer,
2)You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
3)You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
4)Also clean the thin transparent timing strip next to the carriage shaft.
5)With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the print head.
May 18, 2011 | TallyGenicom 2280 Matrix Printer
Hardware alarm 0253-131-000002-3790-1500 After warmup this flashes on the screen.
The hardware alarm you are seeing on the 2265+ indicates the printer is experiencing a "horizontal task error" ie the printer is not able to move the print head or is not able to detect the print head is moving, things you can check to resolve this problem are;
  • Remove the ribbon from the printer, ensure this is not jammed or damaged
  • Power the printer OFF and try manually sliding the print head from side to side, look out for any objects which may obstruct the movement of the print head (pen lids etc!)
  • Ensure the print head gap is not set to close to the paper, thus jamming the print head
  • Remove the paper to ensure the paper is not restricting print head movement.
  • Clean the Optical Timing Strip that runs under the print head, ensure this is not damaged also.
  • Clean the carriage shaft, this should be FREE from any lubricants WD40 etc and dry running. Remove build up of paper dust etc.
If the problem persists it is likely the printer has developed a fault, check the following
  • Worn or damaged timing strip
  • Worn or damaged carriage shaft
  • Fault timing sensor
  • Faulty carriage motor
  • Damaged print head cable
  • Incorrectly connected print head cable
  • Faulty interconnect board
  • Faulty Main Board
Jan 21, 2011 | TallyGenicom 2265+ Matrix Printer
Hardware alarm 0036 131 000004 0376 0009 hardware alarm 0025 131 000004 0376 0009 hardware alarm 0024 131 000004 0376 0009
Hi, the printer seems to have a problem with the horizontal movement of the print head carriage. Turn of the printer and move the carriage by hand to check if there is an area where it can only be moved too hard. If yes, clean the carriage shaft from dirt, etc.
Sep 08, 2010 | TallyGenicom 2265+ Matrix Printer
Red alarm wont go off and printer wont print
Damaged Hardware or firmware. Chances are the printer wont tell you which part.
Sorry. IF you can find a schematic to locate the broken part and replace it yourself, that may be of use to you.
Nick
Sep 03, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
Dec 07, 2008 | Tally T2250 Matrix Printer
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Printer won't print full job
I think their is leser is not taking fully of the document some problem in hardware.
Sep 12, 2007 | Brother HL-2040 Laser Printer
TallyGenicom 2265+ Matrix Printer Logo
94 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
