Question about Sanei N77 Deluxe Tablet PC
Plz help? The tablet doesn't go any further than the loading screen, is there any way to reset it at all?
Try pressing the power button for 5 to 10 seconds. The tablet shall turn off.
Posted on Apr 24, 2014
    Problem Solver:
  • 18 Answers
Try this: Turn off the tablet, then Hold down the Vol + and Vol - at the same time for about 10 to 15 secs. If this takes you to recovery console, do wipe/factory reset.
Posted on Apr 22, 2014
  • 1 more comment
  • James Blake
    James Blake Apr 23, 2014
    Didn't help nothing happened when I done this
  • ntj888 Apr 23, 2014
    You may try Google " Livesuit for Allwinner A13 " and use that program to reflash the tablet firmware found here :http://www.saneimall.com/download/
    or better follow the instruction on this site:http://veedee.in/forum/index.php?topic=1...
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
Jul 29, 2015 | Tablets & eReaders
My tablet wont come on. whenever i turn it on it just comes to the loading screen and says system loading. then it wont go any further its stuck on the loading screen. what's wrong it?
Sounds like a previous update did not finish installing due to being switched off in mid stream or it got corrupted.good news is you can reset android tablets to factory settings...bad news is you will lose all you settings and apps which you will need to reinstall once it is up and running.most tablets reset in the same way.
switch off ...then whilst holding the up volume and the home button hold down the power button then continue holding just the vol up and home button.it will display the robot then you can let go of all the keys and follow on screen instructions to reinstall factory reset.
some tablets are a little bit different to reset...instead of volume up its volume down.if you google your make and model of tablet it will describe correct procedure...one last thing...do not panic if it doesn't reset first time...some Chinese based tablets may take two or three attempts to reset.
Jun 11, 2015 | Tablets & eReaders
Loading issues please help xx
Hello chloe you ned to free some of the memory by closing all resent used apps and IF the tablet is unresponsive you may be requierd to perform a hard reset your tablet
Resetting your device to Factory Defaults If you need to reset your device to the factory default settings for any reason please follow the process below:
WARNING!!!
Please be aware any information currently on the device will be permanently erased by following this procedure.
  1. Go to applications screen and touch the settings button.
  2. Touch the Backup & reset option.
  3. Select Factory data reset.
  4. Leave the erase SD card option unticked & touch "Reset tablet".
  5. Touch "erase everything".
  6. The unit will now reset itself back to factory reset and any previous information/data will have been permanently erased.
Getting further help and support
Please see our support site below for further help and support with your device including how to install software updates if available and much more:
http://getsatisfaction.com/geminidevices
Manufakturer
http://www.geminidevices.com/7030.html
manual
http://www.geminidevices.com/manuals/GEM7030-Manual.pdf
Jan 05, 2015 | Android Gemini Tab
Problems with Azpen A727 tablet.
Soft Reset Press the reset button on the back of the tablet with a fine point object for about two seconds. This will not erase data store on the tablet. This may help if the screen is frozen or not responsive to touch.
Nov 24, 2014 | Tablets & eReaders
Why doesn`t my icraig tablet load?
contact craig and have them mail you a memory card with os on it unless they have it listed on website.-
Aug 02, 2014 | Craig CMP741d Tablet
It wont turn on
If it just hangs at the loading screen (doesn't turn itself back off automatically), you might need to do a factory reset on it. How you do that varies between each model of tablet.
Mar 09, 2014 | Tablets & eReaders
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
Oct 18, 2013 | Tablets & eReaders
Power problem with Onix 7" tablet
The screen just flashess white i dont understand wat do do plz mi hopeles without it someone help me asap plz
Jan 27, 2013 | Tablets & eReaders
I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
Jan 08, 2013 | Supersonic 7" Touch Screen MID Tablet
Sanei N77 Deluxe Tablet PC Logo
Top Sanei Tablets & eReaders Experts
Are you a Sanei Tablet and eReader Expert? Answer questions, earn points and help others
