Question about Canon imageRUNNER 5000 Copier
Please show me images about hopper connection
    Problem Solver:
  • 5 Answers
Open front door, to the right side,theres a great box,look to the right side of the grey box, and you will see a small connector,look to see its female part,and insert connector. The hopper is where the toner emties into,hope this helps and good luck !
Posted on Apr 22, 2014
I have electolux W600H washing machine it is not starting when we push start button (secure hopper) this massage is showing display please help me
sounds like the hopper door switch is not locking into place (maybe worn through use) making the machine think that the hopper isn't closed.
2 options, re-align switch closer to the hopper so as to engage when it's closed... or build up the area responsible for activating the switch.
i did the latter on my washer door (similar fault) as it was easier to add some melted plastic with a soldering iron rather than take the whole thing out, turning it over then fiddling with the door switch.
if what you call the hopper is the dispenser drawer then you can get to the switch inside by removing the top/lid (couple of screws on the back, slide top/lid back half inch the lift it off)
Nov 16, 2017 | Washing Machines
Error code c2557, please how i can soluction??
The code references an abnormal low toner density in the black IU.
Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle. When moved to the upper position, it both locks the bottle in place and opens a cover on the bottom of the bottle.
It is possible the toner hopper itself is not functioning as well. Either the motor drive is not working, that is, broken, or there is a problem with the printer control board that it is connected to. This is a rare problem and not very likely.
Also, it is possible the image unit itself is defective...the sensor could be at fault...or its not pushed in correctly to make an electrical connection.
Feb 19, 2014 | Konica Minolta Bizhub C452 Copier
The problem is about error 000002 0000 for my ir6000
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Feb 14, 2013 | Canon imageRUNNER 7200 Copier
My Canon IR5570 shows error E000020-0002. What shall i do?
This is the error indicating that the connection for the developing hopper toner sensor is not detected at power on. Check this connection and the toner sensor for the hopper may need to be replaced. Good luck.
Sep 14, 2011 | Canon imageRUNNER 5570 Copier
A copier model sf 2220 shows F2 pls what can i do to that?
hello,
you have not installed the developer (it's a steel-colored envelope that must be purchased separately if not included in installation). To do this you need to remove the toner cartridge that you entered, and remove the screw with a screwdriver blue. slip off the drive containing the hopper and fill the whole bag well distributed along the developer hopper. Reinsert done this, tighten the screw and install the toner and error F2-40 is resolved. if you need instructions let me know. Hello Valerio
Jul 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
My projector shows diferent color, green on the top and normal color on the botom but it shows image
the light polarizer on one of the lcd panels is fried due to excessive dust and heat and will need to be replaced. unfortunately, you cannot get individual parts of the optical engine from philips, so you'll have to replace the whole optical engine.
Dec 17, 2009 | Philips Hopper SV20 Multimedia Projector
Error code e000020 in ir6000
E020
General condition
General condition
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Hi i have fargo dtc525 card printer i am using that printer scince 1 year, now not working error massage HOPPER 1 EAMPTY this type of message showing please tell me solution.
hopper 1 empty means that you do not have any cards in it. The printer has 2 hoppers, and your program maybe defaulting to hopper 1. Select hopper 1 and cards to it and that should solve the problem.
Nov 30, 2008 | Fargo DTC525 ID Card Printer
Error code E 000025-0001
 hello i m ramy,first  replace the toner bottle, second check the hopper motor connection,
 hopper motor unit gears.
or test if there 24 vdc .to the motor
Mar 27, 2008 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5000 Copier Logo
32 people viewed this question
old marine
old marine
