Question about Electrolux Washing Machines
Dead front loading washing maschine
Dead. Is there a fuse that can be changed? There is a blue relay, looks like a pressure sensor, says ITW Metalflex ST540 on it, could that be dead? The alternative would be the PCB in the front, that would probably be the most costly part to replace.
  • 5 more comments
  • Electrolux
    Electrolux Apr 22, 2014
    Good Afternoon Rene,
    I see that your Electrolux washer seems to be dead and you are wondering if there is a fuse that can be changed. I really want to be able to assist you with this; however, I will need the model number of your appliance to better assist you. I will be looking forward to hearing from you.
    WP
  • Rene
    Rene Apr 23, 2014
    Hi, the model is EWF10741
  • Rene
    Rene Apr 24, 2014
    There's a program dial on the front of the washing machine, normally selecting a program switches off the LED display. It worked fine a few days ago, now nothing happens, zilch, so obviously something is broken. There is power at the wallplug so that is not the problem. I've had the top off the machine and see 3 areas that could cause this. First there is the switch panel where the mains power cable enters. It's very difficult to access in the bottom of the cabinet so I can't easily see if there's a fuse or anything in that area that could need replacement. Then there is the aforementioned pressure sensor, and the PCB at the front of the machine that has all the consumer electronic - dial, LED etc. I'd assume the PCB probably is the most expensive part to replace so I'd start by checking fuse and pressure sensor first. What does the pro think? What is the most likely part to cause complete failure like this.
  • Rene
    Rene Apr 24, 2014
    Should say *switches ON the LED display.
  • Rene
    Rene Apr 25, 2014
    3 days and no useful reply. I guess this forum isn't really ready for prime time yet huh.
  • yes there is a fuse at the back of the cover machine refuse it with 2arms flex
  • Rene
    Rene May 01, 2014
    There is no fuse to be seen on the back cover outside. Do you mean inside the cabinet? It doesn't seem to be easily accesible from the bottom. I can remove the top (lid) of the cabinet but very difficult to access the cable junction box at the bottom.
Illeagle
  • 525 Answers
SOURCE: dead Maytag washer
You will need to replace the lid switch assembly, not just the fuse. Below is a link that will go directly to an enlarged image of what you need, along with ordering and shipping information.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1468&PPStack=1
Note: Lid switch adjustment may be required when installing new kit. If instructions do not come supplied with the kit, post me back and I will try to guide you through it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 18, 2008
  • 19 Answers
SOURCE: 95 Jeep grand cherokee dead battery everyday
You need to check the battery drain. Disconnect the negative terminal of the battery and using a multimeter between the negative terminal of the battery and the now disconnected negative lead check the amperage which is being drawn from the battery. Your reading should settle anything between 0.03 and 0.20A but hopefully nearer the lower end. If it is above this then you will have to systematicly disconnect each electricrical item until you have a good reading. Once you have get a good reading on the multimeter you should be able have a good idea of what was causing the drain. Good luck
Posted on Dec 15, 2008
bunnydawg
  • 5158 Answers
SOURCE: Dead battery replace, died again 3 days later
12 volt is actually a misnomer of sorts... it's actually closer to 13.8 volts i believe. if the voltage regulator is not working right you could very well be frying the battery. replacing it is the cost of the alternator + labour (unless you do it yourself).
Robert
Posted on Dec 16, 2008
  • 51 Answers
SOURCE: syncmaster 740 power supply problem
I would check all the transistors (especially the larger ones) for shorts. If you can separate the power supply from the other circuits (such as by unplugging a connector to other boards), I would do this and see if the fuse still blows. If it doesn't, then the trouble is in another area, perhaps the LCD driver circuits.
Posted on Dec 30, 2008
dustyboner
  • 356 Answers
SOURCE: dead cylinders 2003 sebring
it sounds like you may have the wires on the wrong coil. It should be #1 on the #4 coil, and the #3 wire on the #2 coil. you probably have them backwards so 1 and 3 are firing on the exhaust stroke.
the firing order is 1-3-4-2.
they should be hooked like this.
Posted on Jan 24, 2009
What is the blue wire that plugs into the fuel pump on a 2000 Lincoln town car with a 4.6 motor
At the fuel pump, pink with lite blue tracer is voltage.
I looked at the fuel pump relay , there are two lite blue wires with orange tracer. I divide the relay into two sides, load side, has the arm with arrow head, that lite blue wire is voltage, you can see the fuse. The control side of relay is that coil looking symbol, that lite blue wire is ground controlled by computer.
Dec 09, 2016 | 2000 Lincoln Town Car
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
Washing maschine runs for 5 sec and trip
PE code stands for "Pressure sensor Error" check the sensor and the small tube that is connected to the outer tub for debris.
Dec 18, 2013 | LG WM-2277HW Front Load Washer
When i turn on my washing maschine it takes in water as normal but when its time for it to spin it does nothing so it trys to take in more water and the same thing happens again then it turns it sel*** and...
you have to check the water level sensor, included to check the small hose from the drum to the water level sensor. there must be pressure from the water to suppress these sensors, the operation of the washing machine are:
washing process / cycles will start when the water level, which we set is reached. then there is pressure from the water through a hose, pressure water level sensor.
while SPIN is the reverse process of the washing process, water in the drums will be drained through the drain valve. and there is no pressure in the water level sensor so that the spin will start.
Jul 14, 2010 | Hotpoint Aquarius WF220 Front Load Washer
When the machine is switched on ALL the lights
when the washing maschine is switched on all the lights are flashing,...you can´t switch that on or off,..you have to unpluged the maschine,...we are unable to wash any clothes
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I want circuit daigrame for aeg washing machine
I have an AEG öko Lavamat 64600 washing maschine and I need a circuit diagram. Can you help me?
Thanks,
Bridget
Dec 30, 2008 | AEG Lavamat 88840 Front Load Washer
Whirlpool duet washer model: GHW9200LQ 1-2 minutes into the washing cycle washer shows error code HF.....there is water in the washer.....checked faucets....checked hose for leaks..I had to use the spin...
I found this in when I looked it up.
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. - or -
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operati
Aug 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
