Question about RCA HD61LPW165 61" Projection HDTV
How to change out rca lpw42 color wheell
Tv cuts out after about 30 min. Conn"s tech said it was color wheel and that it would cost 1000 for the wheel not including labor.
  • RCA Master
  • 8,617 Answers
That tech must not know much about RCA Tvs Heres a link to the correct color wheel for your model and they will even assist you with instalation for free.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-212184/cName/color-wheels
Posted on Jun 20, 2009
After the tv has been on for about 30 minutes the picture starts flickering really bad and eventually will go completely white like where it looks kind of like negatives? it works perfect for that first...
The colors wheel could dies at any time of the tv life,at any monent without any period of times.The colors wheel run at RPM spinning revolution are 1000 RPM a min. to make colors for this tv.The problems u discribing are one problem of the effect of the colors wheel is dying and worn out.The colors flashes like film negative,the picture flashes Black&White withtin the picture.Replace the colors wheel again,will solved this problems.
Nov 20, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
My RCA Scenium HDLP50W151 TV makes is making a loud whining sound that varies in degree. I have picture and sound but the noise is beginning to drown out the TV volume
All projection TVs for RCA are DLP TVs, with that in mind these TVs have a lamp inside that produces white light. The color wheel is the one in charge of giving color to that light. Regularly the color wheel last between 2 to 5 years depending on the daily tv use. Most of the time when the central barring of the wheel is loose, unstable, or out of place it will cause the edge of the wheel to make contact with the housing, producing that whining, whirling, screeching or hissing sound. These sounds can either produce just a annoying sound when watching tv or can cause the tv to shut off. When this happens you’ll have to replace it, if you want to know where to buy, you can look in ebay, there are many parts you can get at very good bargains, the only thing is that you buy at a high risk of the part not working ( I had a bad experience). The other option is to buy at an electronics store online dedicated at selling tv parts, some can help you trouble shoot your problem and others may have tech support over the phone (personal recommendation: Discount-Merchant.com ). And last remember to search your part by part number, NOT by model number, two TVs with same model numbers but assembled on different dates ( different generation TVs ) will have none compatible tv parts inside, so be very carful.
Dec 24, 2009 | RCA Televison & Video
My picture is gone crazy
Call a good TV Tech and have him replace the color wheel assembly.
Jul 29, 2009 | RCA HD50LPW175 50" HDTV
Whining noise on start up, lamp and TV shutting down
The TV tech isnt too familliar with RCA TVs. The color wheel is the most likely problem no where near 1000. Depending on the model number of your set you can get replacement color wheels at the following link.
Jun 13, 2009 | RCA HD52W59 HDTV Projection Television
Does any one make a replacement color wheel for my rca #hd50lpw62ayx2 projection tv? And if so, replacement procedure to replace. Thanks
You can find a replacement color wheel for a model # HD50LPW62AYX2 at this following link:
RCA HD50LPW62AYX2 Replacement Part Color Wheel
I'm not sure about how to correctly replace the part. Hopefully a tech whose dealt with this model will post an installation guide.
Dec 15, 2008 | RCA HD61LPW165 61" Projection HDTV
Buzzing noise from lamp area.
if your model is the HDLP50W151 your color wheel is 212.00 at the following link and they provide free instalation instructions and also free tech support to help you with the Indexing when your finished as all color wheels in RCA TVs have to be indexed after instalation. You need color wheel 212184 heres the link
Click on the color wheel catagory on the left column.
Jun 26, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Whining noise problem and color flickering
Its the color wheel you can get a replacement color wheel for your model and it comes with free instructions on how to index it proprly plus free tech support with on line messageing. heres the link.
Jun 18, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
Picture flickers, loses color, goes green, white, and negative, then TV turns off.
the unit has a bad color wheel.rca has seen this problem before.The color wheel has a bad bearing which over time can seize causing the single color you see.Keep on them they know it is defective
Mar 19, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW165 61" Projection HDTV Logo
208 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
