Hotpoint wdd960 Strong smell of mouldy water
  • 3,247 Answers
This is usually because there is water in pump which does not get drained over time. Leave the porthole door open from time to time to let the odour out. Make sure the laundry drain backflow has not dried up causing sewer smell to come through.
Run the washing machine empty using a packet of cleaning agent available from supermarket. see this site
http://www.hillmark.com.au/products/scalexplus.aspx
Posted on Apr 22, 2014
3 Suggested Answers
  • 118 Answers
SOURCE: Fabric Softner Tray
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Posted on Sep 02, 2009
  • 29 Answers
SOURCE: hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Posted on Nov 10, 2009
Hotpoint washing machine wdd960 is leaking from underneath.
either tub has a leak or one of the hoses has a leak somewhere? if u remove the cabinet then run machine u can see and locate ur leak more easily? by the way a tub leak can be repaired some times with some water proof selant
Jan 09, 2015 | Hotpoint Washing Machines
Get some tide washing machine cleaner, it'll clear it right up.
Apr 22, 2014 | Washing Machines
Hotpoint WDD960 Washer Dryer - no error code but whenever I put it on a dry cycle it just spins as if working but without actually drying. Any suggestions?
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Jan 28, 2011 | Hotpoint Washing Machines
Hotpoint wdd960 washer dryer error f05
Nov 08, 2009 | Washing Machines
SMELLY WASHING MACHINE
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
Oct 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
