Question about Dell AY410 Multimedia Speaker System
Right channel not working
Even with headphones the right channel is not workin. How can I open the bass unit as the ampli connections are only there?
Behringer BXR1800H blown fuse?
Might be a fuse, yes. It will require to open the unit to service. Do lights still come on? Have you tried headphones with it?
This unit takes a 100-120V T 6.3A H 250 V SLO-BLO fuse. They can be found at Radio Shaft. ;) Good luck!
Oct 26, 2012 | Behringer BXR1800H Ultra Compact 180 Watt...
Creative Gigaworks T20 (series I) Left speaker just producing noice, until I turn the Bass knob counterclockwise towards "minus" - then there is sound in the left speaker but even more noice...
The problem that developed with my Creative Gigaworks and other is that occasionally it would not play at all. When the problem occurred, I could eventually get it to work again by turning it on and off several times. I opened up the powered unit (the Right speaker with the controls and found that the wires were really crammed in there, such that a white ribbon wire connector on the bottom was straining to the point of where it was slightly cracked. While playing audio through it, if I touched that wire ribbon, the sound would cut out. So I adjusted the wires slightly to relieve any tension force on that connector and it has not had the problem since. I would open up that unit and check for a similar poor or strained connection. To open the unit, carefully pull off the fabric speaker cover straight off, remove the 4 rubber inserts in the top 4 holes, and remove all 6 philips-head screws in those deeply recessed holes.
Jun 03, 2011 | Creative Labs GigaWorks T20 Computer...
Skullcrusher Bass not working.
You might want to check out my tip on replacing dodgy cable/plugs on headphones.
May 13, 2010 | Skull Candy Skullcrushers Headphones
There's no sound in the game, except in the beginning. Not in the title screen though.
if u have connected a 5.1 channel speaker...some games does not support 5.1 channel mode..u should use an headphone ..will work.
Sep 09, 2009 | Simon & Schuster Bass Avenger for Windows
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
Bass amplifier doesn't work even when i switched the batteries.
The bass unit must be defective. Talk to the guys at Skullcandy for a replacement (they offer lifetime warranties for stuff like this).
Their website has a link directly to the warranty page as well: www.skullcandy.com/warranty
Hope this helps
Apr 14, 2009 | Skull Candy Skullcrushers Headset
1 phone not working
WTF??? My shits stopped workin now to!!! LMAOO.. what a POS!!! hahahahaha, I see all you fawlkers with the same prob on the same pieces of shits!!! hahahahahaha, I am dyin laughin oer here!!! hahahaha, wow, what dicks... they dicked us on effin headphones.. fukkin bums!!!!! LOL
ohhh sheeeiit... time to go buy new ones i guess... BASTIDS!!
Oct 15, 2007 | Sony MDR-V150 Professional Headphones
Right speaker channel low, both front and and back, even the headphones
There might be a levels adjustment in the setup menu for distance or something, might check that before opening unit up.
Jul 08, 2007 | Sony STR-DE445 Receiver
Dell AY410 Multimedia Speaker System Logo
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
