Question about Hand Tools
What size cleat/staple do I use for 3/4 hardwood flooring?
I just purchased a MFN200 and it did not have a manual.
  • 27 Answers
FLN-150 is 38mm staple and FLN-200 is a 50mm staple. you can buy them online in boxes of 1000. I would say choosing between the two depends on the thicknes of flooring you are using.
Posted on Jun 23, 2009
Nail cleats are not exiting when the mallet hits on my Bostitch MFN-201. The spring mechanism appears quite loose; you can push it down or in very easily by hand.
That is most likely what needs to be replaced as that is the return spring. If it is weak it may not be allowing the driver to go back up far enough to let the next cleat load into the nose. Here is the parts diagram. Bostitch (Stanley Tool Works) just merged with DeWalt so you can get the part from either company now or a dealer of either company.
http://servicenet.dewalt.com/Products/Detail/MFN-201
Jul 23, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
My MFN-201 cleat driver will not drive the cleats deep enough into the 3/4 inch prefinished bruce flooring. It postitions the cleats fine. It is on the Rachet setting.
There is a piece of rubber under the head called the bumper. This rubber piece is what stops the driver from forward travel. If you remove this rubber or replace with thinner, you can drive nail deeper. Most likely your driver blade may be worn or where driver blade attaches to shaft may be worn. Tool would need to be disassembled to check. Parts are not expensive and available at www.bostitch.com Good luck
Apr 06, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Oct 02, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
The staples are not going deep enough into our hardwood. We tried a different nailer as well, and the cleats wouldn't work either. Tried both 1 1/2" and 2" staples and cleats. We're installing 3/4 inch oak...
The working pressure of this tool is 85 - 90 PSI max. Do not over power it or you risk O-ring breakage. These guns are adjustable for floor thickness. The adjustment is simply by adding and removing shims on the floor contact part of the tool. For 3/4" the pad should be 5/16" thick without shims
Jan 03, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
I am using a Bostitch MFN200 Manual Flooring Nailer and we are having some trouble with it. The cleats go almost all the way into the floor board but are still sticking up about an inch out of the board....
2 things come to mind. I've installed Wood Floors for the last 5 years.
Make sure you have enough Air pressure running to the stapler,
and Second, Whack the hell out of it. You can be rough with it. Their designed to take a beating
When u hit it with the mallet, youre opening a valve which shoots the piston and drives the staple into the boards. hit it not hard enough, not enough air is being sent to the piston to drive it fully.
Aug 02, 2009 | Stanley Bostitch Industrial Manual...
Question regarding Bostitch MIIIFN or MIIIFS
Read the warranty for Woven Strand Bamboo floors. I think you find this is the wrong tool. You`ll probably find that you need an 18ga 1/4" crown, so it don`t split!
Thanks,
Jeff
May 02, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
My Bostitch Manual Flooring Nailer MFN200 is only 3 months old and inner parts by the spring have broken....this should still be under warranty , but is there a repair kit
From what I can see at StanleyBostitch.com there is not a repair kit for this tool. Given the age I would take in for warranty service.
Jan 12, 2009 | Stanley Bostitch Industrial Manual...
Hand Tools Logo
157 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
