Question about Tools & Hardware - Others
Kompernass parkside I have a parkside palm sander model PHS 160b2, where can I buy sanding sheets
    Top Expert:
  • 34,089 Answers
From the point of purchase?
Posted on Apr 22, 2014
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
  • 10865 Answers
SOURCE: Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
Posted on May 02, 2009
  • 104 Answers
SOURCE: no sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Posted on May 23, 2009
  • 226 Answers
SOURCE: black and decker model 7404 1/3 sheet sander - not orbiting
I read elsewhere of someone using JB Weld to fill in the pentagonal hole in the bottom plate, after coating the armature of the motor with a light coating of oil to keep the JP Weld from sticking. Assemble, and set aside for the JB Weld to set up.
tom
Posted on Jul 13, 2010
SOURCE: Finding parts for Craftsman 4x24 sander model
craftsman belt sander just stopped - does craftsman still have life time warrenty?
Posted on Aug 01, 2010
Palm sander
The answer "Go to Dewaltservicenet" can be confusing - the actual site is servicenet.dewalt.com and even then, entering your part to get to manual can be infuriating. This is the link for the current model which, for all intents and purposes, is the same. The link to the helpful page is: http://www.dewalt.com/tools/woodworking-sanders-orbital-sanders-d26441k.aspx . You'll get a pop-up box with a dropdown that has a few numbers, nothing else. Just click on "1" and ignore language that indicates that this model has more than one - it does not. After you click on "1", the pop-up disappears that you're on the d/l page. Downloads are in the upper right corner. You want "Instruction Manual".You should get to this page: http://servicenet.dewalt.com/Parts/Browse#6229 but may not, it's very glitchy. On this page, you'll want to make sure "Sanders" is on the left and "sheet" is on the right. If you try to get the Manual from the DW411 page, a blank page will open. Make sure your pop-up blocker is off or that you allow dewalt.com. The instructions for the d26441k are identical to the dw411 - same technique for loading sanding sheets, same rods, etc. I've uploaded the d26441k page manual .pdf so that should help. It's easy to get lost on the Dewalt site while trying to find somthing so simple. :)
May 24, 2014 | Dewalt DW411 quarter - sheet palm grip...
Can the platen on DW411 be replaced
Yes it can be replaced. If you go to www.ereplacementparts.com, you can look up your sander and find the parts you need. You can buy the parts there or get the part numbers and search the web for pricing.
Dec 03, 2012 | Dewalt DW411 quarter - sheet palm grip...
Sandpaper keeps coming off while sanding. Why and how can I remedy situation. I was thinking about replacing rubber cover on clamp.
I switched it to a new pad and the sandpaper is still flying off :( I just don't get it the paper is not even half used up. my sander is the hook and loop velcro one ugh its driving me nuts I have to keep buying more sandpaper when the sandpaper is not even worn out! BTW Mines a dewalt hook and loop random orbit sander
Jan 03, 2011 | Bosch 1297DK 14 Sheet Palm Sander Kit
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
Where can I get instsructions for the Dewalt DW411 Palm grip sander and also what type of sand paper do I get to fit it.
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
Oct 05, 2010 | Dewalt DW411 quarter - sheet palm grip...
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
1/4 palm Sander is not "collecting" dust even with a new sanding bag, what could be the problem?
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
Jun 23, 2010 | Makita 1/4 Sheet Finishing Sander with...
No sanding action and motor just buzzes
Mar 30, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
Tools & Hardware - Others Logo
113 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
