Question about Maytag MMC5000 Microwave Oven
Microwave works perfectly except heating food
    Top Expert:
  • Maytag Master
  • 34,193 Answers
There could be controller or magnetron failure or an open fuse.
Posted on Apr 22, 2014
  • Vern Stires
    Vern Stires Apr 22, 2014
    if you have lights and a turntable working it is the magnetron or the fuse protecting it.
  • Ted H May 05, 2014
    A failed magnetron or open fuse seem like reasonable answers BUT...you should receive an error message or error code if either of these had occurred. I think you should also receive an error code if a wire had been dislodged in the magnetron power circuit. So, I'm going to suggest your has a relay that turns the magnetron 'ON' and that this has failed or is not being energized by the control electronics.
SOURCE: Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Posted on Feb 12, 2009
  • 82 Answers
SOURCE: everything works on the microwave but wont heat food.
You need to remove the cover, (Power Unplugged!!) look for and check a long glass fuse (usually in a plastic housing)
It's 5000 volt and less then one amp rating.
It's a small wire inside fuse so check it with a meter.
If it's ok, it's most likely the Magnetron which is usually half the price of the machine.
If the fuse has blown, see if there is a black diode, 30-40 mm long, one end is screwed to the case.
Disconnect one end, If you have continuity both directions, it's failed causing the fuse to blow.
Replace that diode / high voltage rectifier and then the fuse.
You should be back in business.
jb
Posted on Mar 16, 2009
  • 6 Answers
SOURCE: microwave wont heat
Check out the door switch. Could be malfunctioning.
Posted on Aug 06, 2009
heatman101
  • 43501 Answers
SOURCE: My microwave is not heating food?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fsghgs
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
heatman101
dghj
My microwave is working perfectly but just won't heat my food
Set your power level to high. Your manual will tell you how to set it.
Oct 15, 2014 | Microwave Ovens
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
GE microwave model JVM1750DM does everything except heat food. Worked this morning fine.
Chances are the magnetron has failed, "heats food" the other possibility is the high voltage capacitor and diode. Repairs will approach the cost of a new microwave oven.
Apr 19, 2011 | GE JVM1750DM Microwave Oven
Microwave works except not heating food
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
Microwave is not heating food
heatman101
fs
Mar 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
Maytag MMC5000 Microwave Oven Logo
110 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
