Question about Acer Aspire 5610-4648 Notebook
Acer 4738 Cursor moves on touchpad but I can't click
SOURCE:
  • 95 Answers
SOURCE: acer aspire 5620 touchpad problems
Go to acer website and look for support/then driver download/select your model/and download/do RUN instead of SAVE
Posted on Aug 31, 2008
  • 8 Answers
SOURCE: acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Posted on Jan 19, 2009
SOURCE: frozen touchpad
I followed the advice of pressing the FN and F7 keys at the same time. It didn't work when the program was fully loaded, but I rebooted and tried again during the rebooting and it worked. I had the frozen cursor on the Travel Mate (Acer) also.
Posted on Apr 17, 2009
kevin000
  • 1847 Answers
SOURCE: Problem with my laptop cursor or touchpad
The first step that you should try is to reinstall the touchpad drivers.
Still no good reinstall the OS,
Still no good replace the touchpad.
Thanks
Kevin
Posted on May 27, 2009
ta_mcguire
  • 125 Answers
SOURCE: acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Posted on Jul 30, 2009
How do i copy and paste on acer c7 chromebook
"to copy and paste a paragraph" - I just used my c7 to copy the prior phrase from you the text in your question and to paste it into this "add your solution" answer box. Here's how I did it...... 1-I placed the cursor in front of the word "to", and while holding the touchpad down with my left finger, swiped the cursor through the phrase to the end of the word "paragraph" (thereby highlighting the desired phrase), then lifted both hands. 2- With the cursor over the end of the highlighted phrase, I used my left finger to hold down the "alt" key to the left of the touchpad the clicked the touchpad causing the drop-down copy menu to appear, then lifted both hands. 3-I then used the touchpad to move the cursor over the word "copy" in the drop-down menu and clicked the touchpad.
4-Then I placed the cursor in this "answer" text-box clicked once once. Next I held down the "alt" key to the left of the touchpad and clicked the touchpad to cause the "paste" drop-down menu to appear and raised both hands. Finally I moved the cursor over the word "paste" in the drop-down menu and clicked the touchpad, thereby successfully copying and pasting the phrase from your question. PS - an alternative to holding the left alt key and clicking to get the drop-down menu is to place two fingers on the touchpad (about a half inch apart) and click with both fingers simultaneously. The latter method only works about 75% of the time for me, so I recommend using the alt key.
Apr 10, 2014 | Acer C7 Chromebook
Acer Laptop Help
To get started with this product, complete the following steps.
Turn the laptop on by pressing the Power button located above the keyboard.
Locate the touchpad.
You use the touchpad much like you would use a mouse.
The touchpad controls your cursor.
It responds as you move your finger across its surface.
Move your finger across the touchpad to move the cursor.
Locate the bar below the touchpad.
This bar may be used for selecting and has left and right-click functions that you can use a mouse.
Clicking on the right end of the bar has the same effect as right-clicking with a mouse.
Clicking on the left end of the bar has the same effect as left-clicking with a mouse.
Tapping the touchpad is the same as clicking the left end of the bar.
Use the keyboard like you would use a desktop keyboard.
The only difference is that the keyboard of an Acer laptop is smaller than a regular laptop keyboard.
Click on the Windows icon in the lower left side of the screen to access programs.
Make sure your wireless switch is turned on, if you want to access the Internet.
Then locate a wireless network.
Windows may automatically detect and display a list of available networks.
If that happens, you only have to select the network you wish to access.
If it is not your network, you may need a password if it is security-enabled.
If Windows does not automatically detect a network, open Internet Explorer, and follow the on-screen instructions to connect to a wireless network.
Acer user guides and manuals
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ACER
May 24, 2013 | Acer Aspire Computers & Internet
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
Hi,I had a problem in my touchpad,acer aspire 5738g.i just open it and my touchpad didn't functioning already,i can move the cursor but when i click it i won't.please help me what to do.
if you can still moved the cursor,but not able to click it,there a possiblity that there is something wrong with the driver itself,you can also try to check the settings of the mouse
Jun 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire One Netbook Touchpad
fiddle with your cursor settings in control panel under mouse settings
Mar 14, 2010 | Computers & Internet
My touchpad cursor on my laptop will starts clicking things...
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Jul 25, 2009 | Acer Aspire 5720-6661 Notebook PC
Cursor is frozen and can;t move on my laptop
Plug in a USB mouse, and go to Contol Panel>system>device manager and click on the +sign next to pointing devices. Right click touchpad and uninstall the touchpad, then reboot the computer, remove the usb mouse. Windows will pick up the touchpad as new hardware and re-install the drivers for it etc..
I hope this helps
Dec 05, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5610-4648 Notebook Logo
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
