Question about Samsung Computers & Internet
My monitor on my hp8300 stays in sleep mode
I have a HP 8300 all in one PC. when i start my PC it switches on and then the monitor goes to sleep or in blank. computer is still on and yu can connect via another pc and work. if you change some settints the monitor comes on again and you work normally but when you swith off and on again the same things happen.
    Top Expert:
  • Samsung Master
  • 7,501 Answers
You need to turn off sleep mode its sounds as if its on a timer setting.
Posted on Mar 30, 2015
freetek
  • 5568 Answers
SOURCE: Screen Goes Blank on Gateway Laptop
I would suggest connecting your laptop to an external monitor via the VGA port to see if the system is causing the problem or the display section.
It sounds like the latter.
If it is, then it could be a premature failure of the backlight lamp or the circuit that drives it, either will be less costly than a processor or main board repair.
BTW, I am desperately looking for an affordable replacement (we are very rural) for People PC; it is the lousiest ISP I have ever had and am really tired of their buggy software which never seems to improve and complaints are either ignored completely or given lip service by suggesting ineffective, stupid, fixes.
Posted on Jun 30, 2008
Pyrhyc
  • 2028 Answers
SOURCE: The Laptop can't get to sleep mode
Do a system restore ro a point that you remember it working properly.
Posted on Jul 17, 2008
Fixe_You
  • 1800 Answers
SOURCE: Toshiba Laptop Stuck in Sleep/standby Mode
maybe u got problem with the flex cable that connect the lcd to keboard/mouse
Posted on Aug 27, 2008
Geekman
  • 32281 Answers
SOURCE: toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 04, 2009
SOURCE: HP Pavillion Entertainment PC screen blank, power lights on
try this put off the laptop and remove the battery and the power cable and then hold the power button from 30-60 seconds then put back the power cable(without battery) and switch it on it should work then shutdown and put battery pack in
Posted on May 10, 2009
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
Hp elite l2201x monitor won't work
I am experiencing the same issue. My monitor will not come out of sleep mode. HP informed me to purchase another power cord, but it yielded the same results. Any solutions????? Thanks
May 28, 2012 | Dell Computers & Internet
The monitor starts up and goes into sleep mode
After repairing the on/off button for $100.00 and then rehooking up the monitor to my pc, the monitor has power but stays asleep even when I push in the menu button, I can't get anything to happen. HP techs tell me that the problem is with my computer although it worked perfectly fine before I unhooked all to send out the monitor.
I hooked all back up again as before but now the monitor will only say "monitor going to sleep" and nothing happens.
Wishing I had a solution. Thanks
Sep 10, 2010 | HP f2105 21" LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
HP LE1901w -- monitor starts then goes into sleep mode
welcome my friends ,, all about football here !
http://www.news-football.org/ Football News
diego goals vs barcelone ! here ! Football News
Apr 24, 2010 | HP w1907 LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Computers & Internet Logo
26 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
