Question about Refrigerators
I have an LG side by side fridge/freezer model no: GR-B206GTQA that I have recently purchased second hand. When I plug the unit in it runs ok for approximately 10 minutes and then the condenser fan st
Hi, I have an LG side by side fridge/freezer model no: GR-B206GTQA that I have recently purchased second hand. When I plug the unit in it runs ok for approximately 10 minutes and then the condenser fan stops and then an error code ER CF is shown on the display. The codes indicates a problem with the fan. I have cleaned the condenser fan and coils etc as this area was thick with dust and fluff and I have replaced the fan motor with a new one which is the correct motor for this model but nothing has changed. When plugged in the compressor runs fine (no clicking) the coils heat up and the fridge/freezer cools but the fan will only run for approximately 10 mins. When the fan stops (this is when the error ER CF appears) the compressor continues to run and I have noticed that the edge of the divide between the fridge and freezer section gets hot. I had also noticed that the bottom of the evaporator cover inside the freezer looked a little warped/melted, I removed the cover to find that some of the fins on the evaporator had been damaged/bent, I have done my best to separate and straighten the fins so although these are now not touching each other they still out of shape. Could this damage in any way be associated with the fan not working as it should? I should also mention that if I turn off the fridge and leave it for only several minutes the fan doesn't come on at all but if the fridge is left unplugged for several hours the fan will run but only for approximately 10 minutes before stopping and the error message is displayed. I cannot find a suitable solution online anywhere and would be very grateful to anyone who can help me. I can attach a video or photos is this would help. Many Thanks, Lee
Check the realy on the controll panel
Posted on Apr 23, 2014
  • Lee Hardy
    Lee Hardy Apr 25, 2014
    Hi Munene. Thanks for your response. Where exactly would I find the relay? Behind the display panel or under the cover on top of the unit? How would I check it? Thanks again, Lee.
3 Suggested Answers
  • 16 Answers
SOURCE: I have a Hotpoint HSS25GFPEWW side by side.....
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Posted on Aug 15, 2012
  • 966 Answers
SOURCE: Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Posted on Dec 30, 2013
Hi, I have an LG side by side fridge/freezer model no: GR-B206GTQA that I have recently purchased second hand. When I plug the unit in it runs ok for approximately 10 minutes and then the condenser fan...
You probably need to replace the fan blade or housing. They are available online and are not too much more of a job than the fan motor was. It was likely not the fan motor giving you the problem since they are rather strong.
Apr 22, 2014 | Refrigerators
LG GR-B206GTQA Fridge Freezer ER CF Error Code
The fan is almost certainly run by a sensor in the condenser. If it doesn't get hot enough, the fan doesn't run. Sounds like short of gas. Try wiring the fan to the compressor live and see if it runs all the time then.
Apr 18, 2014 | Refrigerators
I bought a LG GR-349SQFrefr/freezer second hand yesterday for my doughter. Before buing it they tried it, and the freezer got cold OK. After installing it it seems that the freezer is working OK, but the...
If you transported it on its side or carried it on its side for a while and did not allow about six hours standing time before switching it on, you may have burned out the motor because the oil/gas mixture will have been dispersed into the system and needs time to drain back into the compressor. In this case there is nothing to do but call in a repairman and possibly replace the compressor..
Mar 27, 2011 | Refrigerators
Hi i have an LG GR-B206GVQA fridge freezer when we got up this morning it was not working at all i tried the fuse nothing wrong with that i tried the fuse on the control board on top of the unit that was...
Did you check the plug its self ? By plugging a lamp in the plug where the refrigerator is pluged into ? If the wall plug is good (could there have been bad weather) and then you plug fridg. back in and no positive results check to see if the inside light bulbs are good and work.
Aug 02, 2010 | LG LSC26905TT Side by Side Refrigerator
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Jan 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
