Question about Radio Flyer Steer and Stroll Deluxe Trike
Handle to push trike snapped inside
Handle no good to guide trike
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
Can't assemble the push handle in little tikes 3 in 1 purple
Hi Blanca,
We'd recommend you contact Little Tikes direct for assistance -
Mar 05, 2014 | Little Tikes 3 in 1 Trike Purple
The steering bar is not even with handle bar. The child's handle bar is straight, but the push bar will then be crooked to the right.
I put some packing tape around the bar to where the handle bar fits. It is holding for now, i don't know how long it would stay :)
Jul 11, 2011 | Radio Flyer Steer and Stroll Deluxe Trike
The handle snapped off my mower. Everything else works fine, but It's useless without a good way of pushing it. How do I get a new handle?
Hi and welcome to FixYa. I am Kelly. The handle is in 2 parts. The lower handle and the handle extension. You can order them here:
https://www.reelin.com/ItemGroupItems.aspx?ItemGroupID=58
31108-2 - LOWER HANDLE 20" RH - QTY 1 EA. $6.30 button_in_cart_new.gif 31108-3 - LOWER HANDLE 20" LH-BLKTX - QTY 1 EA. $6.30 button_in_cart_new.gif
31098-3 - CENTER HANDLE SEC-BLKTX - QTY 1 EA. $7.05
button_in_cart_new.gif 31099-3 - TOP HANDLE SECTION-BLKTX - QTY 1 EA. $6.15
Hopefully you know which part of the handle that you need.
You can contact them here:
American Lawn Mower Co.
P. O. Box 369
Shelbyville, IN
46176
Consumer Hotline: 1-800-633-1501
Email: Sales@reelin.com
Thanks for using FixYa.
Kelly
May 30, 2010 | Great States 20" Scotts Classic Push Reel...
Loose handle
bottom of handle is a screw hidden behind a square little sticker thing. use a small screwdriver to pry it out. take out screw and then push handle upwards and it will come off a clip which you can now tighten. then snap top secti0on of handle back onto clip and then lower screw secures it.
Nov 09, 2009 | Freezers
I am attaching a new interior door handle on the driver side. Do I have to take the whole cover off or does it snap in
No you can use a screw driver to punch off the clip on the inside of the handle if you push the door cover in near the handle turn the handle till you see the end of the clip that holds it in place then pop off the clip with a flat screw driver, Be careful of it springing away and hitting you in the Eye, and be careful that it does not spring off where you can’t find it. Once off put the clip on the new handle and push it on the gear crank then push clip in to seat
Jul 03, 2009 | 2003 Ford ZX2
Driver's side interior door handle snapped off
there is plastic snaps that attatch the panel to the door all the way around the panel which you can buy a tool to remove the panel without breaking the snaps,the door handle may have a cable hooked to it that releases the latch and it might be stretched causing the handle to pull hard
Apr 24, 2009 | 1989 Ford F 150
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Radio Flyer Steer and Stroll Deluxe Trike Logo
Top Radio Flyer Toys Experts
Tom Chichester
erex 01
erex 01
obsteiner
Are you a Radio Flyer Toy Expert? Answer questions, earn points and help others
