Question about ASUS Eee PC 1015PE
Need to enter bios, but password protected
My wireless networek adapter wont connect . i need to access bios to change settings, when i try to enter setup i'm asked to enter current password.I need to bypass this.
tmaddonna
  • 10 Answers
SOURCE: Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
Posted on Sep 03, 2009
  • 2385 Answers
SOURCE: I need password to enter bios setup to change boot
You don't need to access bios to change boot drive just hit escape key a couple of times when you power on and it will give you options for which drive to boot from.
good day
Posted on Nov 03, 2010
  • 8909 Answers
SOURCE: i WANT TO GO TO
The password is a password that was set when the first user set the notebook up. There is no record of it except by the person who wrote it.
Posted on Dec 17, 2010
mariolands
  • 2296 Answers
SOURCE: I need to change boot
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Jan 10, 2011
  • 43 Answers
SOURCE: Hi, i can't enter to
You should be able to use the ESC key during boot up to get a boot device menu. During the same time you would press F2 to enter BIOS. You also, if needed, can reset the bios password(and all settings) by clearing the cmos chip. warning, this will clear all bios settings! use if truly needed.
hope this helps!
Posted on Jan 25, 2011
How do I use the password protection?
Your questions isn't too specific but I hope this helps
There are several ways to incorporate password protection. You can set the computer to require a boot up password in the computer BIOS. You have to enter the computer BIOS as soon as you turn it on; with a Dell press [F2], with HP press [Esc] and select system configuration. In the BIOS you can set the BIOS Administrator password - controls the ability to change BIOS settings, the computer boot password - when enabled it requires the user to enter the bootup password before the computer will boot, and set the hard drive access password - controls the users ability to access a hard drive.
The next level of password protection is at the operating system level - account access levels, privilege levels, and passwords. Dependent of operating system you can also set hard drive encryption
Oct 28, 2014 | Maxell MAXDATA 503802 - FLIX8G HIGH-SPEED...
I cannot connect to the internet
Which operating system ?
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
you might be able work your way through the problem
Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter.
The usual procedure is to plug the wireless adapter into an available USB port.
Windows will install the appropriate driver.
After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars).
A list of available connections will appear.
Select the desired connection.
If you are prompted for a password, enter the appropriate password.
Click "Connect."
You are subsequently connected to a wireless network.
Launch your browser and enjoy surfing the Internet wirelessly.
If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel."
Then select "Network and Internet" and "Network and Sharing Center."
Click "Change adapter settings" in the left pane.
Double-click the icon of the appropriate wireless connection.
The Wireless Network Connection status window appears.
Click the "Wireless Properties" button.
Select the "Security" tab and select an encryption type from the drop-down selection.
Enter a password in the Network security key field.
Make sure that the password matches the router settings.
Press "OK" when done.
Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area.
You can buy these online, or at electronic stores.
You'll need to set up your router using the accompanying instructions and your own Internet service provider.
This is best in a home with multiple computers.
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled,
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
You only need to check the following if a driver cant be installed
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"imake
May 30, 2013 | HEWLETT-PACKARD RECERTIFIED TOUCHSMART 300...
Not able to connect to my netgear login. I clicked on a button and now it wont connect. Any Suggestions
You need to configure the Netgear wireless router first.
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 13, 2013 | NetGear Computers & Internet
No connect wifi
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 23, 2013 | D-Link DIR601 WirelessN 150 Home Router...
The security setting changed to access my wireless
Hello there!
Well, there can me a lot of small little problems for you this time. I suggest you to firstly logon your router via his general ip adress. After you change wireless password entry settings (i suggest you to use wpa2 systems, I suppose you dont need bigger security if its home network) , you should then check your wireless reciever, restart it, refresh transmiter to search new connections, and when it founds your name connection, i.e. Dynex G, click on it and it should automaticly asks you for a password. Enter it and save it. Thats about it.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Dynex Wireless-G USB 2.0 Network Adapter
ICANT CONNECT WITH MY NEW DELL NETBOOK WITH MY WIRELESS WGT624 CANT GET IP ADDRESS INSTALLED
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Jun 20, 2009 | NetGear WGT624 Wireless Router
My router is detecting the internet but i cant get the internet on my computer. I cant connect to my router but it says that im connected with limited access. I have it hooked up through the router with a...
Limited or no connectivity indicates that the computer cannot acquire a valid IP address. This is due to incorrect network key you have entered. We need to check the correct WEP key in your router's setup page. Here are the troubleshooting steps we recommend you try:
Note: You need to use a computer hardwired to the router to check the wireless settings.
Apr 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Limited or no Connectivity WG111v2 SBG900
Limited or No Connectivity on Windows XP
Feb 28, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have new Sony Vaio Laptop and Sony Vaio All in One computers with internal Intel (R) Wireless WiFi Link 5100 network adapters and I am trying to connect to a Rangemax WPN824 (MIMO) router. I can see the...
Possible reason why your computer is not getting online wirelessly is because the wireless settings on the router and the wireless settings on your computer do not match. Here are some troubleshooting steps that I suggest you try:
A. Checking the Wireless Settings of the Router
1. Open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Jan 01, 2009 | NetGear RangeMax WPN824 Wireless Router...
Can't connect home comp to laptop
how many wireless computers do you have?
is it a dekstop or laptop?
if desktop have you installed a wireless adapter? if laptop, is it using a built-in wireless adapter, have you enabled the wireless adapter or have you installed a wireless adapter?
please make sure first that the wireless adapters are installed properly or enabled on your computers, if everythings OK.
access the setup page of your router and change the wireless settings of it.
how to access the ui
- open the internet explorer
- on the address bar type in 192.168.1.1 hit enter
- enter admin under password, leave it empty for the username and click ok
- click the wireless tab
- set the wireless mode to mix, change the wireless network name or ssid with any preferred name you want to use, make sure to enabled the ssid broadcast and then click save settings.
- after that, under wireless tab, there are sub tabs, click wireless security
- set wireless security to WPA-PERSONAL, and under passphrase, enter your desired password for wireless connection, take note of it and please be reminded that its case sensitive.
- click save settings.
for your wireless computers, if adapters enabled and working fine, on the system tray you should have an icon for the wireless connection, doubles click on it and it will pop for the wireless connection window wherein you can see the name that you set on your router, all you have to do is select the name click on connect and it should ask you enter a password, enter the passphrase you set on the router and click connect. then check if you can go online, if yes do the same thing with other computers.
Have a great day ahead.
Sep 28, 2008 | Linksys WRT160N Wireless Router
ASUS Eee PC 1015PE Logo
20 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
