Question about Hisense TL-3220 Television
The Hisense remotye will turn the tv on and off, but other functions will not work., We have always had trouble with this remote. We can not program a universal remote because there is no code. Help. Is there a way to replace the remote ? That is if a new remote will solve the issue???? it is a Hisense TV TL3220 thanks
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: We have just purchased a
I doubt you will find a universal that will work on this set. The company is in southern China and out of business. I have one someone gave me and it needs a board (the remote works fine).
I tried 4 different universal remotes and not one worked on the Hisense set.
Good luck and next time pass unless they have the original remote.
SD TECH
Posted on Aug 05, 2010
jyackle5
  • 8197 Answers
SOURCE: I am looking for remotes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
Posted on Nov 09, 2010
gopakumarg43
  • 75774 Answers
SOURCE: need a universal remote control code for Hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Posted on Dec 19, 2011
Having trouble finding out whether it's my remote or TV that is the problem? Need help!...I have a Hisense led lcd 32" model number HL32K160L. long story short, I turned the TV on at its main power button...
Hi sounds like the remote control unit as it is a transmitter not a receiver, have you tried rubbing your hand firmly over all the buttons on the remote just in case a button is stuck down.
Hope this helps
Oct 21, 2017 | Hisense Televison & Video
Hisense Remote
Use the "auto search" method to program the remote and it found a code on its own and get your tv unlocked. Try using 0478 code
Oct 17, 2008 | Hisense TC24FS2H TV
Can I please get a TV code for Hisense 55M7000UWG to use with TiVo Recorder remote?
0272,0274,0283,0219. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 16, 2016 | Hisense Televison & Video
The GUIDE button on the remote (model EN-33926A) for a Hisense 55K610GWN does not work
my children messed around with the remote and now i can turn the tv on from the actual tv but from the remote when i press channel up or down or hdmi buttons it turns the tv of.. remote model en-33926a
Dec 19, 2013 | Hisense Televison & Video
No remote 4 tc24fs2h
You can get a replacement remote (substitute) from Remotes.com: http://remotes.com/store/hisense/tc24fs2h.html . This only controls the TV functions. A better substitute remote is available from Amazon: http://www.amazon.com/gp/product/B009H5N0BU/ref=as_li_ss_tl?ie=UTF8&tag=mywayshop-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B009H5N0BU .
Some universal remotes may also work. You will need one that was programmed 6 months or more after the TV was released. Also make sure that you get a remote that can match the Menu and Input functions. Some cheap universal remotes only match the basic functions of the original remote. Some features of the TV can be controlled by pressing buttons on the TV but not all.
I hope this helps.
Jan 11, 2013 | Televison & Video
Need a universal remote control code for Hisense tv
Hello
0073 0182 0216
10748
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
I need the code to program a rca systemlink3 remote for a hisense tv
0748...but if its like mine it wont work. these HiSense remotes are JUNK!!!
Aug 17, 2009 | Televison & Video
Programming remote to hisense tv model # LCD1504US
Cable remotes and TV remotes often are incompatible.
Sep 27, 2017 | Hisense LCD1504 15 in. Television
Need remote control code for hisense EN-21660A
Does anyone know where I can get a remote for a Hisense 22" TV? I've bought a universal remote but after reading other people's experiences with the Hisense remote, I'm reluctant to even try it.
Dec 23, 2008 | Hisense LHD3206US Television
Televison & Video Logo
99 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
