Question about AMD Sempron 145, 2.8 GHz
No audio device plugged - AMD Sempron 145, 2.8 GHz
    Problem Solver:
  • 5 Answers
Try doing a system restore back to a time when everything worked correctly. Many times, they come un-configured.
Posted on Apr 22, 2014
No hdmi audio output except Roku 2.
You didn't mention whether you switched inputs on your TV for the different devices. Fix could be that simple.
Apr 30, 2016 | RCA Televison & Video
VOX is stuck on. How can I fix?
Many times when a radio gets stuck in VOX mode it is because an audio device was plugged in while the radio was turned on. Try turning off your radio and then plugging in your headset or other audio device. If this is not the issue, post back here on fixya with the model of radio and type of audio device being used.
Best regards.
Feb 15, 2016 | Radio Communications
When I plug in headphones the radio goes into transmit mode.
This is a common problem when the audio device is plugged in when the radio is turned on. Be certain to have your radio turned off when plugging in the audio device.
If this is not the case, your audio device is not compatible with your radio, or your radio has a bad accessory jack.
Best regards.
Apr 19, 2013 | Cobra Electronics Corporation New-radio,...
No audio output device installed
Under sounds no audio is installed, scan for hardware changes, still no luck try this: Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally. Check device manager for audio, scan for hardware changes. reconnect to tv.
Nov 06, 2012 | Computers & Internet
My speakers are plugged in and connected but there is no sound and it says there is no audio device. how do i fix it
Check that the speakers are powered on (assuming they need power) and that the volume control is set at a mid-level.Next check that you have the speaker 3.5mm jack plug inserted into the correct speaker socket on the audio card - there are normally three sockets, one each for a microphone, speaker or headphone output and for line output - these are often colour coded on newer systems and if so, match the colour of the speaker jack plug to the speaker socket.If the speakers are connected by USB instead of an audio jack plug, then check to see if the USB device has been recognised automatically - if not, then you may need to find any software that came with the speakers and install this before the system will recognise them.Finally, open the system audio controls and check what device is selected for audio output - ensure that this is the same as the speaker device you are wanting to use.One further test, if you have the speakers powered on and they have a standard audio jack, you should hear some feedback sound if you touch the contacts at the end of the jack plug with your fingers.
Dec 20, 2011 | Audio Players & Recorders
No sound in my computer
These are some of the steps you can try to make sure all is ok at your end,
Check if the correct audio services are running
Identify if your audio device is disabled or turned off in Windows
Check if your audio device is muted
Identify if the volume of your audio device is set too low to hear
Check if the audio device is not set as default
Determine if your audio device is plugged in
Thanks.
Jun 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I need to add and auxillary input to my 2003 chevrolet silverardo bose radio. how can i wire one in?
THE GM12-AUXV2 by P.I.E. will work for you.
It plugs into the factory radio changer port.
With this device installed, you will have created an auxiliary audio input to your factory radio, which will allow you to plug in any external audio source, like a portable MP3 player, satellite tuner, DVD player, or iPod, and play the audio from that external audio device directly through your factory radio. This is a direct connect device and NOT an FM Modulator. An FM modulator requires you to tune to an FM radio station in order to listen to the audio from the external audio device. While this is a direct connect interface, it is only an audio connection and does not allow you to control the external audio device that is connected to it.
Jan 19, 2009 | Car Audio & Video
Plugged in speakers, but computer can't find the device?
Maybe your audio device not compatible to your speaker, try update your audio device.
Jun 12, 2008 | HP Compaq dc5700 Microtower - Free Flat...
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Will not recognize Midair 25 (drivers installed)
Sounds like a USB issue. Is the device self powered? Did you try plugging in a different USB cable? Is it plugged into a powered hub?
USB 1.1 devices and USB 2 devices can cause issues together on the same bus or port. Try keeping devices separate or plug in just the maudio device. I had issues with USB Network adapters not being seen all the way because there was a older usb 1.1 device on the same hub.
Feb 15, 2008 | M-Audio Audiophile USB Audio and MIDI...
AMD Sempron 145, 2.8 GHz Logo
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
