Question about Car Audio & Video
How do i remove the door panels off a 1990 honda accord ex 4 door
How do i remove the door panels from a 1990 honda accord ex 4 door and what is the speaker size in the doors??
    Genius:
  • 1,114 Answers
There's a special tool used to pop the door panel off the the door frame. You could use a flat blade screwdriver as well, but this tool will do a better job. Get the door trim tool at auto parts store (pretty inexpensive).
First is to locate all the screws on the door panel, usually located on or near the arm rest/ door pull and on the trim where the door handle is located. In your case there may be small "buttons" which cover the screw heads .Use a small screw driver or small pick to lift these buttons which will expose the screw head. There may be one of these buttons on the upper portion of the panel as well. You just need to look for them. Then you insert the trim tool between the panel and door frame and pry the panel away. The panel is held to the frame with trim buttons or fasteners. Sometimes these fasteners break when they are popped, but they are replaceable(again, auto parts store).
Be careful not to pull too hard or yank the panel too far away from the frame , so as not to pull off any wires (speaker wires, elec door lock, etc). Once the panel is free, then its a matter of lifting up to disengage it from the top portion of the frame, where the panel channel fits into the frame on the inside of the window.
Speaker replacement - go to any electronics store that sells auto speakers and they can tell you which speaker will fit your vehicle. Or you can go on line. Look under auto speakers or audio, and again many sites have this fitment info for your vehicle.
Posted on Jun 21, 2009
Where is fuel pump on 1995 honda accord ex
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Remove the access panels in the luggage area.
  3. Unplug the electrical connector from the sending unit.
  4. Disengage the retaining collar using a fuel sending unit removal tool. This tool is available at Honda dealers and many auto parts stores.
  5. Remove the sending unit from the vehicle.
  6. Installation is the reverse of remova
Aug 22, 2013 | 1990 Chevrolet K1500
I need to replace the driver side door knob. I beleive I will have to remove the door panel. How do i do this? Ir is a 1991 Honda Accord EX.
Leave the window rolled up:
remove the lining
remove the two bolts 10 millimeter
you may need wiggle the latch out and unhook it from the outside of the door or you may have to reach up inside to remove the latch
Good Luck Tim
Apr 17, 2011 | 1991 Honda Accord
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Jan 25, 2010 | 2004 Honda Accord
Automatic seat belts 1990 honda accord ex they just quit working and no red light in dash "seat belts does not work nieher. Fuse? if so were is it? or something else?
It is most likely the door switch does the interior light come on when the door is opened if not replace the door switch, this switch also controls the seat belt motor.
Dec 08, 2009 | 1990 Honda Accord
94 Honda Accord EX 4 door, VTEC motor, PWR windows/locks. The left rear widow will not roll up any more. Every thing else is still working. This is weird because I hardly roll that window down. That are...
not weird at all,you dont use ,so its jammed up.end of story ,remove door panel and give motor a light wack with something not to heavy whilst someone hold the switch in the up position with engine running to give an bit more voltage to window motor
Dec 07, 2009 | 1994 Honda Accord
Where is the dipstick for the automatic transmission fluid for a 1990 honda accord ex 4 cylinder
it is on the top of the transmission. there is no tube so it is directly in the transmission case. it is black or red and on the front side of the top. let me know if you have any more question. good luck
Nov 26, 2009 | 1990 Honda Accord
1990 honda accord ex. The engine won't turn over
maybe clogged fuel filter of weak fuel pump. and maybe a faulty starter or battery
Nov 02, 2009 | 1990 Honda Accord
I need instructions on how to remove/install headlight assembly on a 1990 civic ex 4 door
open the bonnet, unlock the latch for head lamp cover the and remove the head lamp cover and replace the head lamp.
Sep 18, 2009 | 1990 Honda Civic
Remove driver's side window switch
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you can disconnect the harness connecting to your window switch and remove it
Sep 10, 2009 | 2001 Honda Accord
Car Audio & Video Logo
828 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
