Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WD640 Door Lock Light not coming on
Power light is on, wash light is on but the door lock light does not come on when the door is closed and the machine does not start.
    Prodigy:
    An expert who has answered 500 questions.
  • Hotpoint Expert
  • 517 Answers
Check the door peg is not loose or it is the door lock
Posted on Apr 27, 2014
  • 146 Answers
SOURCE: door lock flashes
Your switch bracket or switch is either broken or you have no either to or from it. Check your switch first.
Posted on Dec 18, 2007
cerikitten
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Posted on Feb 24, 2009
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Posted on Jan 22, 2009
beltronic205
  • 1474 Answers
SOURCE: hotpoint aquarius wf101 washing machine wont start
fit new door interlock switch not too expesive parts about £15
Posted on Apr 07, 2010
  • 1382 Answers
SOURCE: Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Posted on Jun 28, 2010
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wt640 door locked light does not come on. I have changed the door lock module but still the same fault.
I assume that the power is okay and getting to machine,if yes then try off/on switch faulty pole its a two pole switch,if your unable to test do not have a multimeter/ then you could short out the poles just make sure its the correct ones are shorted otherwise may damage or blow a fuse.....good luck.
Apr 21, 2011 | Hotpoint Aquarius WD640 Front Load...
Door will not open
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
I got a hotpoint wmd940 and on a cycle it bleeps and says door is open
Hi.
If the door is closed, then the Door Lock micro switch may need replacing.
The switch can be tested by a technician bypassing it or reading impedance to see if micro switch is opening and closing.
Try first disconnecting power for a couple of minutes to reset the control board.
If you need to contact a technician call the number listed on the owners manual.
Regards.
Dec 17, 2009 | Hotpoint Aquarius WD640 Front Load...
I have hotpoint wma62 and door lock light flashes, machine will not start as door will not lock any clues ???
Hiya,
yes, i can help..
Firstly, lets start simple. Have you noticed the door lever/handle has got "floppy"? or loose? or easy to squeeze?
This is the most common reason, what happens is there are 2 bits of spring steel behind the handle, these either break or become weak, to test this theory, close the door, put your finger between the handle and the door and push the handle towards the glass, if this works then you need a new spring/handle.
Please let me know,
Please rate my help.
Regards
Sussex engineer.
Oct 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Door locked light flashing when door is closed
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd64
Check power is at these Points.
  1. Mains filter at top right - Check for live and Neutral Presence.
  2. ON/OFF Switch - Check for Power in and Out when switched on.
  3. Door Lock - Check for Power down 1 wire and when Locked, Power ( Live ) present in 2 wires. The third wire is the Neutral for the door locking circuit. Check this Neutral is OK. - Let me know.
Mar 12, 2008 | Hotpoint Aquarius WD640 Front Load...
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Mar 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
126 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
