A red square appears on the bottom left screen of my veon 58inch tv. Only happens every so often
A red square appears on the left bottom of my 58inch veon tv. It only happens every so often. Not sure why
5 Suggested Answers
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
taran_2005
  • 10515 Answers
SOURCE: TV turns on but no
Kindly provide few more details :-
1.The red light that you mentioned - is it a power light or stand by light ?
2. Is there any sequence of blinks or is continuously lit?
Thanks!!
Posted on Sep 18, 2010
techman007
  • 1112 Answers
SOURCE: I have new Philips LCD 47"tv and on the bottom
HI:
You may of turned on the Philips Easylink which is for connecting Easylink-compliant devices that are connected through HDMI connectors can be controlled by a single remote.
You can restore the default picture and sound settings of your TV.
1. Press MENU
2. Select SETUP> Installation>Then Factory settings.
3. Select Reset to start resetting
5. Press OK.
6. Press MENU to exit.
Posted on Jan 24, 2011
spr1949
  • 1182 Answers
SOURCE: Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Posted on Aug 29, 2012
I have a Veon TV/DVD . I want to hook it up to a Samsung VCR/DVD player . if I want to play a video what channel on the veon TV do I play it on. Or is there something I am doing wrong Julie
Hi if U r using 3 RCA cables RED WHITE ,& YELLOW connect them to the input sockets on TV red is audio & white is audio yellow is picture then set the TV to AV .. INPUT.cheers
May 14, 2016 | Samsung Televison & Video
My Veon 32'' tv wont turn on
Usually fuse near cord interior in case. Teardown. Careful..VOLTAGE danger even unplugged. Touch nothing else.
Apr 17, 2016 | Televison & Video
Veon tv
then you should probably buy one
Jul 04, 2014 | Computers & Internet
Veon tv manual
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
This link says that your TV doesn't come with a Remote and DVD cannot be ejected without the remote :
VEON 19 LED TV DVD FREEVIEW COMBO A1823511 1
Jun 28, 2014 | Televison & Video
My veon 32" has no picture but sound only
Hi my veon tv is 50inch LED turning on green then off red but no picture it had sound but not any more so no picture or sound can't find reset either and is 2 years old please help.thank you
Nov 24, 2013 | Televison & Video
My old analog Zennith TV is displaying in what appears to be wide screen. This happened all of a sudden. Can I fix it or is it dead.
could be a deflection problem or if picture is somewhat small top or bottom or both only a vertical problem--if very old set parts may no longer be available.
Oct 15, 2012 | Televison & Video
Out of alignment (red)shadow
Ur tv convergence are dead.U must know how to solder.U must have soldering tools,and solder to fix convergence problems.Must repalced 2 STK convergence ICS and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 15, 2010 | Sony KP-57WS500 57" Rear Projection...
I just updated my grafics card to the ATI Radeon 9600 Series and now my tv screen is streched out and not in the original square formate. how do I fixit?
Right click in the middle of the screen and and a grey box will appear. Go to the bottom and select 'Poperties'. The Display Properties box will appear. Click on the 'Settings' tab. Move the slider labeled 'Screen Resolution' to the left or right and select the appearance you desire. Click Apply then OK.
Jul 04, 2009 | ATI Computers & Internet
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Recalibration
  1. Remove all games from the Nintendo DS Lite.
  2. Turn the system on by pressing the POWER switch.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • If the above steps did not help, there is a problem with the system and it will need to be repaired. Click here for repair options.
  7. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
  8. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Nov 02, 2007 | Nintendo DS Lite Console
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
