Question about HP P3015 Laser Printer
59.50 error at start up the printer will display the mentioned error code
  • HP Master
  • 783 Answers
This is a main motor issue. Remove the toner cartridge and the paper tray and turn on the printer and see if it comes to asking for cartridge and paper. If still get the error, you can remove the fuser using the instructions at the link below and see if you can turn the big fuser gear by hand. If not then the fuser is preventing the motor from turning.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For:-
HP Support
Posted on Apr 22, 2014
Need help to reinstall my copier hp series disconnected in error l am 90 yrs old need help
Please check if all the wires are connected properly , most likely one of the cables is loose due to rellocation. If not mention what error code you are getting on the display.
Dec 28, 2012 | Office Equipment & Supplies
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
Error 3 showing
Follow the below mentioned steps to resolve the issue : 1. Ensure the Pixma is turned on by pressing the "On/Off" button, you will notice the display prompt you for E3 (error 3).
2. Press and hold the "On/Off" button for one second. The display will now go blank and begin resetting the malfunction.
3. Wait 10 to 15 seconds and restore power to the unit by pressing the "On/Off" button once more.
4. Allow the unit to complete its cycling process and the error code should be gone. If the code persists, your printer will need professional maintenance.
Apr 22, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Printer start & warming up then display lsu error
Please mention the error code to help us guide you better.
Nov 11, 2010 | Office Equipment & Supplies
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
Error shows
Since you haven't mentioned your problem, we only have to assume, in general the error is with copier which actually is E602-0001 error. This means there's problem with the firmware or memory (hdd) of the machine. You'll need to follow the manufacturer's instructions. Good luck. Thanks for using FixYa.
Jun 10, 2010 | Office Equipment & Supplies
Received an error code 50c on my Dell printer
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
Thanks for all the ideas and help ; )
Apr 27, 2010 | Dell A940 All-In-One InkJet Printer
Error code 50C
Hi there Error 50c
This is for the Dell 940 but may do for yours aswell.
color cartridge.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 07, 2010 | Dell A960 All-In-One InkJet Printer
E000733-0001 the err means I have the same problem, the same error code: E000733-0001 on my Canon IR3100CN. I cannot pass to service mode...After I switch off & on, the display shows me the same...
E733-0001 Error Code
E733 and machine locks up with progress bar at 98% on boot up?
I would refer this error to a qualified service Tech.
Deals with replacing DC controller, Main Controller and Boot Rom as a set. Also, mention of replacing the Switching Regulator PCB Assembly if the previous failed to resolve.
May 27, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Code fpf flashes on clock on ge elec stove model jbp26gs1ad
I am sorry, but there is no such error code mentioned among the GE Fault codes.Or this could possibly be because of a faulty display.The display can be replaced on a call.
Else the possible error code similar to this one is "PF" which refers to power failure but generally not related to kitchen range.
Please do check if there is a display change of the error code and post your valuable comments. would be glad to help.Good luck.
Jan 16, 2009 | GE JSP26 Electric Kitchen Range
HP P3015 Laser Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
