Question about Seiko QHR016SLH Clock Radio
SET alarm seiko QHR016
SETTING THE ALARM
3 Suggested Answers
  • 10865 Answers
SOURCE: I am looking for PDF or online instructions for
Go to seikousa.com and email cust service. They will email you an acrobat version.
Posted on Sep 16, 2009
SOURCE: need users operating manual for seiko qhr016
The time should be done on automatic by pressing WAVE.
To set manually:
Press the [SET] Button for more than 2 sec. The Year will pop up set to correct year then press SET again to set date/mth, keep holding till it get to right month n date (the month and date does not set separately). Press SET again and set TIME then press SET again for your choice of 12hr or 24hr.
Posted on Jul 27, 2011
Seiko instruction manual
http://www.seapyramid.net/rt/seiko-qhr016slh-travel-and-alarms-clock-instruction-manual/ Full manual is listed on this link for free download.
Nov 29, 2011 | Watches
SEIKO CLOCK MODEL QHR016 HOW DO YOU SET UP TIME, DATE AND ALARM ?
Once the 'SET' button is pushed & held, & the numbers are flashing, turn it around to the face & use the ALM/TIME set buttons to adjust the numbers correctly. Then, continue on pushing the 'SET' button to cycle through the number positions & adjust everything else in the same way. Then, for language & temperature readout choices, push the 'OPTIONS' button & use the same ALM/TIME set buttons to cycle through the options, making your preferred choice. Be sure to push the 'WAVE' button to choose your proper region so it can receive the time signal. Worked for me. I use lithium primary AAA cells for the longest life.
May 20, 2011 | Seiko QHR016SLH Clock Radio
Looking for instructions for a Seiko digital alarm chronograph solar powered back has 8n1913 the 8 could be a B. Thanks
seiko chronograph set the alarm etc pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 14, 2010 | Watches
Seiko 7t62 Coutura Black Ion; alarm resets NOT to current time but to about 3 hours later?! Yes, I have RTFM ;-)
Click on my profile, then click on TIPS AND TRICKS. There you will find link for all Seiko watch manuals. Download yours and learn how to reset the alarm. Rate me, plz.
Feb 20, 2010 | Seiko Coutura Chronograph Watch
How to set alarm on seiko chronograph sports 100
pull the crown out to the first click press the reset chronograph button until the hands on the small alarm dial start to move.set the alarm time press the crown back!
Jan 15, 2010 | Watches
I have a seiko chonograph couturo alarm. 100m
Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same ....er....time. You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
Now you can set the alarm chime point.
Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
Jan 01, 2010 | Seiko Coutura Chronograph Watch
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Nov 27, 2006 | Seiko Coutura SNA341 Wrist Watch
Seiko QHR016SLH Clock Radio Logo
47 people viewed this question
Top Seiko Audio Players & Recorders Experts
NOEL
NOEL
cwradio73
Andrew Taylor
Andrew Taylor
Are you a Seiko Audio Player and Recorder Expert? Answer questions, earn points and help others
