Question about Boating
I have a 1988 gamefisher outboard motor I need to put a water pump on other than taking the bolts out at the bottom is there any thing else that need to be disconnected before pulling the lower unit thanks rebaker1954@yahoo.com
  • rebaker1954 Jun 20, 2009
    thanks Ill look at it tomorrow thanks alot
  • 37 Answers
Yes!! there will be a cover in the back of the upper part of unit. you will need to remove this and disconnect the shifter from the lower end.
Posted on Jun 20, 2009
    Sergeant:
    Champion:
  • 226 Answers
Make sure you pull the lower unit sloly there may be wires to disconnect befor you remove it all the way hope this helps
Serial where is the serial number for Gamefisher outboard motor I cannot find it for Gamefisher outboard motor where is it
Hello, Ron -
According to information in an owner's manual for a Gamefisher model # 225.581508 15" Transom and a model # 225.581498 20" Transom . . .
(Quote)
The model and serial numbers will be found on a decal attached to the port stern bracket.
(End quote)
Best wishes.
May 07, 2018 | Boating
Seagull water pump failure
Or if you want to do it yourself. There are videos to at the bottom link
  • British Seagull Outboard TRN40700 Water Pump Kit ... www.sheridanmarine.com > ... > British Seagull Outboard Spares The British Seagull Outboard TRN40700 water pump kit including the rotor, the joint plate and fixing bolts.
  • Tips & Tricks - Seagull Outboard seagulloutboard.com/?page_id=74 These tips & tricks are ideas contributed by a variety of Seagull Outboard enthusiasts ... This is best done by substitution of the thick pink water-pump gasket with ...
  • Seagull Fourty Plus, & Cooling Modification - YouTube www.youtube.com/watch?v=cfjpVoazL2Q
    • BY RTEDA
    • 3 MIN
    • 7.3K VIEWS
    2009-08-22 · British Seagull, GFPL series N7 (Dec. 1977). Added a siphon-effect water coolant improvement. With an added tube from the original water ...
  • Seagull FAQ www.britishseagullshop.com/faq.html Does the engine pump water? ( If it does its most likely the cooling system is fine) 4. ... HOW CAN I SOLVE THE ELECTROLYSIS PROBLEMS ON MY SEAGULL?
  • Seagull water pump failure Bing video
    May 09, 2016 | Boating
    How to remove shift rod on 1988 johnson 150gt outboard replacing water pump impeller , cannot find the bolt to release shift rod
    The bolt is under the bottom carburetor it's a 5/16 hex head that you will need a 5/16 flex socket 1/4 drive to get it out.
    Regards,
    Dan
    Apr 13, 2016 | Boating
    I have an old 15hp gamefisher that's not getting fire
    Have u got spark ? Put new fuel in flushed carb and fuel lines ?
    Mar 18, 2014 | Light Outboard Motor Boat Bass Fishing...
    I have a 1979 Sears gamefisher 7.5 hp outboard motor. I replaced the water pump in the gear housing assembly and now i am just trying to reassemble the whole untit back to the motor again. I cannot seem to...
    TRY TURNING THE FLYWHEEL TO HELP LINE UP THE SPLINES ...
    OR PUT THE LOWER UNIT IN GEAR SO THAT WHEN YOU ROTATE THE PROPELLER THE SHAFT TURNS... THAT SHOULD HELP YOU LINE IT RIGHT UP
    HOPE THIS HELPS
    Aug 08, 2010 | Boating
    How to replace water pump on a 1985 90 hp mariner outboard motor
    mcdevito75 Here, If I;m not mistaken the water pump is in the lower houseing, a big job, let the marina take care of it as the water pump should be Changed only if it doesn"t pump at all.
    Jun 16, 2010 | 2004 Mercury Mariner
    I would to replace the water pump on a 1988 6.2 chevy suburban ?
    Hi Friend: I think your asking how to replace your water Pump. OK 1st Thing you'll need to do is Drain your Coolant/Water From Your Engine. With A Drain Pan Under Front of Vehicle Below your Lower Radiator Hose. Take the Hose Clamp Loose enough to Remove the Lower Radiator Hose from Your Water Pump.Your Coolant Will Come Out. 2nd Step Remove Your Drive Belt You can Remove this Belt by taking a 1/2 Inch Drive Socket and Correct Socket Size and Put it on The Center Bolt of your Belt Tensioner and Pull the Tensioner to Release the Pressure on Your Belt,While Holding it at that Poition Reach over to your Belt and Take it Off Say Your Alternator or A/C Compressor, Once you have removed it from Thee Release the Tensioner and Now you Can Work the Belt Out And Away From Your Pulleys that it Ran On. 3rd Now You'll need to Remove your Cooling Fan thee should be 4- Bolts and Nuts You'll Have takje all 4 out Then remove your Fan from Engine Compartment. 4th Your Going to Be able to See your Water Pump now You'll Also see that a Bracket or 2 From Your Power Steering and A/C Compressor are Bolted in Front of your Water Pump, So Remove any Brackets Or Components away from your Water Pump. Now that you have Remove anything in the way of your Water Pump including your upper Radiator Hose. You will Be Able to Take your Water Pump Bolts Out.Remeber where your bolts came out ,Some will be a Little Longer or Shorter.and will need to be put back in the same position. Ok Now All Bolts Are Out Of water pump Assembly, It might come right off ,if not just tap it with a Rubber or Plastic Hammer or take a Flat Screw Driver and Pry It off and away from Your engine. Clean the Surface on your engine of any gasket material or anything else.Completely Cleaned. Your New Water Pump will come with new Gaskets ,put some Gasket Sealer on the Water Pump and Put the Ne Gaskets on correctly by Lining up your Bolts Holes.Let It Set awhile,So Gaskets don't Slip when Mounting it to your Engine,Right Before you go to put the Water Pump on,Put a Little gasket sealer on the Gasket Area, Then Lining up your Holes Start Putting Your Bolts Back In All Bolts Should be Torqued at 40 Foot Lbs.Now to Finish installing the Rest of your Parts. Simply Reverse the Removal of The Water Pump. Hope i have helped you Please Let me Know on How my Solution Has Helped. Thank You: From =d_hubbs
    Jun 08, 2010 | 1988 Chevrolet Silverado 2500
    Where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
    water pump is in the lower end of out drive and there is no t-stat
    May 05, 2009 | Boating
    Water circulation (coolant) thru outboard motor
    Common problem is the thermostats staying closed. If i remember correctly they should be replaced every year. Water should be spitting out on the upper part of the shaft. Good luck on that fishin'
    Apr 25, 2009 | Boating
    Boating Logo
    430 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
