Question about Sebo 7260DG Felix Kombi Nozzle
How to dismantle
Have undone all screws, howto get apart now? Is clogged with dog hair and needs a good clean
The beater bar is making a loud noise, and the dog hair is wrapping around the bar. Why would that be happening?
You probably have dirt or garbage wrapped around your beater bar. Loose carpet strings as well as pet hair will do this. If you see dog hair on the carpet its best to pick it up with your fingers as it will make a mess of a vac. Check your drive belt as it could be on its last legs as well causing the loud noise. Probably should be taken apart and belt replaced and a good cleaning as well. You should give a good cleaning once a year.
Nov 07, 2016 | Vacuums
Vacuum is clogged with dog hair. How can clog be removed?
HI, it's Jim from Crucial Vacuum!
If your Shark vacuum is clogged with dog hair there are a number of general maintenance cleaning tips you could perform to help keep your vacuum working at its peak performance.
First let's check out your brush roll. Is there dog hair wrapped around the roll itself? If so remove it by pulling out the dog hair, or use a razor if its tightly wrapped around. Manually rotate the brush roll to help unearth any hidden clogs behind the roll.
If there's dog hair throughout your unit be sure to empty the dust cup after every use. When the dust cup isn't emptied often this leads to clogs and a loss of suction.
Also, be sure to check your vacuums hose for any clogs, or clumps of dog hair. Stretch the hose out as far as you can. If you notice a clog in a hard to reach place use a broom handle to unclog it.
Your Shark vacuums filters may need to be replaced, or washed and may be a source for a lot of the dog hair in your vacuum. Wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 11, 2015 | Shark Vacuums
Overheating dyson dc14
Probably has a blockage (like that's a surprise). Seriously if you have pets, these vacuums get 'hair-balls' that clog passages, overheat and will shut themselves off to protect the motor. You pretty much have to disassemble to vacuum and clean it thoroughly. You'll usually find the problem while taking it apart. I take mine apart (not the same model) about once a month. I have dogs ...
Jun 15, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Stuck front wheel
I have the same problem, but it looks like no one has the solution. I have taken the screws out of the wheel but that doesn't help remove the wheel to check what is stuck. Help us!
Jun 14, 2010 | iRobot 1100 Dirt Dog Bagless Robotic...
My dogs hair often accumulates in the spinning rod
Try spinning it by hand with no belt. If it is tight, dismantle the bearings at the end and clean out the hair . If it is loose then the problem is likely that your belt has stretched, Buy 2 genuine belts and keep a spare on hand. For best cleaning results , replace every 3- 4 months ( broken or not) , if you have a lot of pet hair
Nov 08, 2009 | Royal 5300 Upright Vacuum
Dyson dc17 animal motor spindle keeps clogging
If you have animals get rid of the dyson and go to a vacuum that has a metal brushroll and better airflow. There is no fix on the dyson they just are not good on hair of any kind.
Jan 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Not picking up anything as well as it used to.
try putting new filters in, and check the hose for blockages,
Iain
Dec 23, 2008 | Eureka Capture Upright Vacuum Vacuum
Washing the cyclone
Hi John.
Try this site for help http://dysonmanuals.llc.nu/
The Dc08 poor suction manual covers complete strip down of the cyclone unit,
Aug 31, 2008 | Dyson DC08 Cylinder Bagless Canister...
NO SUCTION
took mine to repair shop for this problem. Dog and people hair caught up in housing you can't reach.
Oct 28, 2007 | Hoover U8143-900 Upright Vacuum
Sebo 7260DG Felix Kombi Nozzle Logo
14 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
