Question about Craig Electronics CMP646F MP3 Plus Video Player
Craig cma3561 open
Broken/dc socket has fallen iside speaker. how do you open the speaker?
Both left & right socket use the same speaker
The manual I just download from Teac shows two sockets for each speaker. Is this a second-hand model? It's possible that someone has tampered with it, perhaps fitting a headphone socket to the back of the unit with the speakers wired to one plug.
Apr 29, 2016 | Teac DC-D6300 CD Shelf System
When connected to charger red lights keeps flashing but tablet wont charge or switch on
Your dc socket is probably on its way out- soon it wont connect charge at all-bad future outlook on this- return if possible.
Mar 10, 2015 | Craig CMP741d Tablet
What do I need to do to return an item that is still under warranty?
You could call QvC and ask for customer service. Hope that helps.
Aug 18, 2014 | Audio Players & Recorders
I need to open the casing on a logic3 wip027a ipod speaker system. i have removed all 4 srews from the back in each corner but there seems to be some lind of fixing holding the centre of the unit. how
Hi, I opened a Logic3 I-station today (dark grey and silver), and there are LOTS of screws for each side.
- on the side where the line in and DC adapter sockets are, there are 4 Phillips screws including 3 hidden behind rubber covers.
- you need to remove them all.
- for the other side there are 2 at the bottom and a few more on the back under rubber covers.
- but no more other hidden screws.
Then you need to be BRAVE because the bottom and short side are clipped at the bottom.
- you have to lever the front off quite hard to get the clips to release.
- The side without the DC input came off easier, because it has just a speaker in it (and nothing broke.)
- The side with the DC input connected came off and broker the speaker wires away from the speaker because the speaker cable was glued to the back where the ferrite bead is.
Then you should be in, and see the 2 PCBs on front right and nothing but speaker front left.
Hope this helps.
Regards,
tony_bobfan
Mar 23, 2014 | SpectraVideo Logic3 i-Station Traveller -...
Craig wireless portable speaker cma3561 won't charge battery
Batteries are holding back the 21st century. I have the older model of this and my battery went bad very fast. Now I have to keep it plugged in and not just any usb port will work it has to be a usb power supply of at least 2 amps. I keep mine in a 2100mA usb source.
Dec 25, 2013 | Craig Audio Players & Recorders
Have to know how to open joytab
Use a rubber same as to remove iphone screen. Lift screen out opposite end to all the side switches. When screen removed it gives access to power board.
Dec 04, 2012 | Tablets & eReaders
Making my craig bluetooth speaker discoverable
Through basic hacking, the code 0000 worked for me....
I wish it came to me sooner!
Craig Electronics CMA3532BT is the model number -
A tiny cylinder speaker - sounds pretty good for the tiny $$$ too.
MikeFilosa
Dec 02, 2012 | Craig Portable MP3 Speaker - CMA3016 White
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 14, 2008 | Hotpoint WF430 Front Load Washer
Craig Electronics CMP646F MP3 Plus Video Player Logo
Top Craig Audio Players & Recorders Experts
odiegh
odiegh
 Grubhead
Grubhead
Gyula Lacz
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
