Question about Simplex Kaba Ilco Unican 1000 keyless lock
E-760 kaba lock - Simplex Kaba Ilco Unican 1000 keyless lock
3 Suggested Answers
  • 963 Answers
SOURCE: Need a instruction manual for
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: kaba lock won't open with code
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Aug 24, 2012
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Kaba lock won't open with code
Aug 18, 2012 | Simplex Kaba Ilco Unican 1011 keyless...
What's your problem?I HAVE A LOCK THAT KEY WILL NOT LOCK ITS ALWAYS OPEN
I urge you to contact Kaba Ilco technical service and talk to a technician.
Here is the contact information:
Oct 08, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lock has a Best core in the outside handle but door cannot be locked
I recommend that you contact Kaba Ilco directly for technical assistance.
good luck!
Mar 16, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
My kaba gun lock will not open i put new batteries in it i have tried 3 different one but nothing will work. i try to punch in my code and it just peeps at me and i can not get into m gun safe.
I don't have a direct answer, but Kaba customer service can be reached here:
Mar 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
The KABA L1000 Simplex lock that I have won't open from one side of the gate. The master key and correct code will turn the handle, but the latch doesn't engage. The latch will open from the other side...
I recommend that you contact Kaba Ilco directly with your problem.
Feb 02, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Unican LL1011 lock - the code opens the lock correctly. If a wrong button(s) is pressed the lock does not open as I would expect but when the correct code is entered it then fails to open
I recommend that you contact Kaba Ilco with this problem--there may be nothing wrong with it at all, but you need an answer.
Jan 28, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
The plunger does not go in far enough
Jan 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need a instruction manual for programing of KABA lock. Model No. E-760 K
REMOVE THE KEY.
Good Luck!
Dec 22, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
JonSnell Electronic
JonSnell Electronic
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
