Question about NewTek Tek LiveText Titling Software LT080000-0101
Live Text Key - NewTek Tek LiveText Titling Software LT080000-0101
I can not sign in to ebay account using what I believe are my user ID and password
Hi, from my own personal experience the best thing to do is find the live text chat on Ebay and say everything to the live text customer service representative, I hope this helps :)
Jan 30, 2015 | eBay Computers & Internet
Links aren't live
Just a guess... If you've changed from rich text formatting to plain text, that could be the problem. If that's not it, and if your email recipients use Firefox as their web browser with Windows, tell them to select the URL link (highlight the URL text) and then right-click. In the context (pop-up) menu that appears, left-click "Open in a New Tab." This may work in other browsers, too.
Jan 27, 2014 | Computers & Internet
Cursor jumping around while typing text
You wouldn't have some live insect in your keyboard have you? I've seen Microwaves do strange stuff when infested with some tiny insects BUT I doubt it's the case with your machine. I am trying to recall a Keyboard key that I sometimes accidentally press when trying to create a document using Word, etc which does the same or similar to what you've described. It pees me of as I don't know which button I hit, it is one of the main reasons I avoid Word, Outlook, etc. Please let us know if solved, cheers.
May 02, 2013 | Computers & Internet
Change screen font and size
This amazingly easy trick will instantly enlarge hard to see text on your screen!
Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles!
Using these tips you can read screen text comfortably!
With the press of two keys, you can enlarge the screen text without going into your settings.
Simply press and hold down the "control" key, while pressing the "plus sign" key.
Be sure to keep the "control key" depressed while you press the "plus sign" key.
Each repetition will enlarge the text.
This can make reading small text SO much easier!
To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key.
Each repetition will decrease the text size.
also
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text sizes largest to smallest
Apr 23, 2013 | Compaq Presario CQ56-115DX Laptop
How to make the letters bigger on my facebook account
Step 1:
This amazingly easy trick will instantly enlarge hard to see text on your screen! Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . also Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text s largest to smallest
Feb 07, 2013 | HP Computers & Internet
Get larger font on this computer
Hope this helps.
Jan 17, 2013 | Toshiba Computers & Internet
How do i change to font so that it will stay put it keeps going back to 12
Which programs font are you referring to ???
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . Hope this helps
Dec 13, 2012 | Acer Aspire 7250-bz600 Laptop
I have a very small font size on my aol mail. How do I increase the font size
You can increase the font size by going to your browser's settings and changing the font size from there. How to get to these settings depends on which browser you use. An alternative is decreasing the resolution of your monitor.
Jul 19, 2011 | Computers & Internet
How can i text someone living in syria? i live in
You can Send text messages from Mobile.
How To Send TEXT Click here
Syria mobile numbers like follows:
932 xxxxxx SyriaTel
933 xxxxxx SyriaTel
988 xxxxxx SyriaTel
999 xxxxxx SyriaTel
OR
For Sending Free SMS try Here...
(After typing Number you want to Send & message Click on Submit.Don't forget to Type Verification Text in Specified field)
For Your Blackberry's User-guide Click Here (For better Usage)
I hope THIS HELPED you..
Anyway i like to know FEEDBACK..
Thanks for Using FixYa
Apr 10, 2010 | RIM BlackBerry Bold 9000 Smartphone
NewTek Tek LiveText Titling Software LT080000-0101 Logo
Top NewTek Computers & Internet Experts
David Payne
David Payne
Are you a NewTek Computer and Internet Expert? Answer questions, earn points and help others
