The other games works normally There's also points on the text screen and some letters are uncovered by points
Normally this happens because the game you downloaded, also called a rom, is incomplete or is not compatible. The solution is to download a different rom of the same game and see if it works. If not, then you may need to upgrade the R4 software available here, http://www.r4ds.me/download/r4ds.html For a how to video, go too, R4 DS Card Firmware Download And Set Up For R4 DS
Hope this helps.
Which r4 card you used ? is it this one : http://www.modchipfactory.com/wood-r4i-gold-3ds-flash-cart-for-3ds-xl-3ds-dsi-and-ds-lite-p-1.html ? Pls format your micro sd card, then redownload latest kernel firmware v1.64b from official site and unzip it,open the folder and copy the root files into your micro sd card,reput your root nds game files into your sd card as well and see whether it works.
SOURCE: endless loading, no game playing
Re format the SD card with FAT 32 reload the R4 files, create a folder called "games" in the root of the card place your games in there job done!!
SOURCE: Pokemon Diamond freezes up completely on route 208:(
Well, I could answer something like this(though its dead from last year) if you stupid people typed more details. It is very lacking...
Do you have an action replay in?
Have you asked Nintendo(who made the freakin' game)
Please be more specific.
SOURCE: R4 card with games works in my DS.
Hmm, depends what DS your sister has.
The R4 is known to work in both the original DS and the DS lite.
However the new DSi has a block and requires a new type of flash cart.
Even with new firmware updates the R4 will not work on the new DSi.
You'll need to find a cart for the DSi, these are usually rather inexpensive.
Also about the firmware, the type version of your cart might not be supported by the latest update. The fact it stops working in all DSes means that something was wrong.
I hope this helped out a bit.
SOURCE: when i insert the r4 card into ds the screen goes blank
Try inserting it while the DS is turned off.
I don't have an Action Replay in
