Error 21 on smitec cosmos 2000 servodrive - Office Equipment & Supplies
What is the soundtrack for Cosmos 1980?
Cosmos, (Main Theme), Composed by Vangelis
Sep 04, 2016 | Cosmos (1980)
How old do you think a kid has to be to appreciate cosmos?
first watched Cosmos when I was 12. My mom found the VHS tapes and we all watched it together... I remember that I liked it a lot, but looking back I don't think I truly appreciated it for the masterpiece that it was. I would say that a freshman in high school would be old enough to fully appreciate this series.
ERREUR 11 SUR SMITEC COSMOS 2000
This is a Hall Encoder loss signal.
Probably u dont have one connected, so it shows Error 11...
Connect the encoder (Hall Effect) to disable this fault.
Jun 29, 2012 | Office Equipment & Supplies
I would like to obtain a user manual for the LG Cosmos phone
Hi leo114,
Click HERE for the manual of you LG Cosmos Touch.
Hope this helps
Feb 23, 2011 | Cell Phones
How reset The Alarm in Servo SGDB--30AMA Turn off Power dosnt make it. Status 3.
hi
i am really sorry i cant help you on this , the problem i deal in fashion side .i think you need to ask the techincal experts in fixya to solve your problem they will give you the solution you need
thank you
Dec 14, 2010 | Oakley Servodrive Golf Shoe 14 M US eBook...
Can't connect to my webpage using Cute FTP, since I got my D-Link Wireless modem, How can I open up port 21? I get this error: During an FTP session, the following error...
You need to open port 21.
Using the DLINK manual, find out what the IP No. of your modem is.
(i.e., 10.1.1.1)
1. Type the IP No. into your Browser window. Press <enter>.
2. Look through the Modems Firewall Settings to open Port 21.
ELSE
Navigate to : http://www.dlink.com.au/tech/Default.asp
Follow the instructions on the page to select the product etc... and get support. Here you should be able to find the IP No. of your modem.
OTHERE
There is information on CuteFTP's website and also an extensive knowledge base and support section.
1. Navigate to the CuteFTP support area of their site: http://www.cuteftp.com/support/
2. Select which area you wish to look into : User Forum, Knowledge Base, Support etc...
3. In the Quick Search section, type the error into the search field, i.e, socket error = #2000. Press <enter>.
4. Read through the information.
Hope this helps. Regards
Feb 09, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
144 people viewed this question
jasbo
jasbo
