I turn on tv it sees ok then turns itself off
Lg tv model 50pg20d-AA turns on works for about 30 seconds then it turns itself off
SOURCE: LG tv turns on by itself
this problem is with the inner small micro-swtches ,the side buttons inside are getting intermittantely short...changing of those switches will solve the prob. tc--
Posted on Oct 28, 2007
dickgs
  • 22 Answers
SOURCE: TV turn on and off
Your TV has a power problem, it maybe high or low supply voltage that causes the TV to turn it self off because of an error. A technician from the manufacturer knows what error it has just by looking at the flashing standby light. Best is to take it to an authorize service center for repair... ^_^
Posted on Jan 16, 2008
  • 3 Answers
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
gsalmen
  • 77 Answers
SOURCE: lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Posted on Jul 09, 2009
SOURCE: 42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Posted on Mar 17, 2010
On power up the led flashes 6 times and then turns red, tv will not turn on for 30 minutes or so then it works again for maybe 2 -3 hours then it happens again
Your power board is defective. diy price about 50 to 100.00. Check on Ebay with your model # for power board. Board has about 4 screws and 3 to 4 plugin.
Sep 03, 2015 | Televison & Video
Just bought a vizio, the tv turns on real pixelated but fixes itself in 15 seoncds
If I have trouble with a brand new TV I always take it back and am sure to get another brand entirely. Personally I've had good luck with LG, SEIKI, and Samsung.
Jan 06, 2015 | Vizio Televison & Video
I have a LG 50PG60UD - AA television that appears to be overheating. TV starts up ok and keeps working without any major issues. A couple of times recently I have unintentionally switched it off and when...
This isn't an easy fix, it sounds like your power supply board is bad or there is a main board problem. I'd suspect a faulty power supply capacitor or heatsink missing, but you have to bring it in to a tech to know for sure.
Apr 10, 2014 | LG 50PG60UD 50 in. HD-Ready Plasma TV
When i go to turn on my LG 50PG20D-AA plasma tv, the green power light turns on for a couple seconds, the LCD turns on, then flicks off again, it keeps repeating the process until you disconnect the power...
everyone is wrong here.
Disconnect the power from the mainboard the board down on the right hand side.
now short out the auto_gen with a peice of wire while tv unplugged.
after this process plug it in.
You should see a test pattern this will rule out Y-sus and Z-sus problems.
Problem will be main board.
Dec 28, 2012 | Televison & Video
42LB2DE-AA.AAUMLH RUN FOR 30 MINUTES FINE THEN NO PICTURE OR SOUND BUT TURN IT OFF AND WAIT FOR A COUPLE HOURS AND TURN BACK ON AND DOES THE SAME THING?
five years is the life of many of these sets, the only parts sold are boards so I would guess main board but others are possible, I wonder if boards can even be found for a five year old LG?
Dec 15, 2012 | Samsung LE40R73BD 40 in. HD-Ready LCD...
LG 52 Inch Rear Projector TV - switches itself off
LAMP pull it out and see if it looks busted on the inside.
Dec 21, 2009 | LG RU-52SZ51D 52" Rear Projection...
Set turns itself on and off with no picture nor sound
You have a major problem with this set. Could be the main board, the Y-SUS board, or the power board or some combination of these.
Mar 30, 2009 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
LG 71SA1D - 180cm (71
Hi there WebRepOverall ratingThis site has no rating(not enough votes)
I am not sure when you posted this but I have the same model and reading the manual it seems to be the lamp. Please replace the lamp (check the lamp model on the outside of the TV on the right side facing the TV).
Hope this helps
Jul 30, 2008 | LG 42LC2D 42 in. LCD HDTV
LG Rear pro RT-52SZ30RB
When did you replace the lamp last time?
When was TV purchased?
Please reply to lampsale@tpg.com.au
Oct 04, 2007 | LG RU-52SZ30 52" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
