Question about Ilco Kaba 101126d41 Lock Combination
RE-SETTING THE CODE - Ilco Kaba 101126d41 Lock Combination
    Scholar:
  • 101 Answers
You need a key to unscrew and remove the lock cylinder on the inside of lock. Enter the old combination. Look inside the hole where the lock cylinder was and turn the metal part in there to the right. Then turn the knob or lever to clear the old combination.
Enter your new combination and turn the knob or lever to insure it works. Try it again to be sure, then replace the change plug. Always test combo with the door open.
Posted on Jul 14, 2014
Master code
"There are two method of doing hard format on most of the nokia devices.
1.manually
1. go to menu and search for setting option.
2.enter in setting menu and search for restore factory setting option.
3. when you press on restore factory setting it will ask you for code enter 12345 the default code.
now you are done.
2.USING CODE.
DIAL *#7370# on main screen.a menu will pop up like restoring all data press ok enter 12345 default code.you are done now.
TO RESTORE SETTINGS ONLY.
USE THE CODE *#7780# "
Aug 18, 2013 | Nokia 7310 Cellular Phone
Whats the master reset security code for nokia 1616, and hw do enter the code. Tnx
THE DEFAULT CODE FOR ALL NOKIA HANDSET IS 12345.
IF YOU DID NOT CHANGED YOUR SECURITY CODE THEN THIS WILL SURELY WORK.
JUST FOLLOW
  1. OPEN MENU>SETTING>PHONE SETTING>RESTORE FACTORY SETTING
  2. RESTORE FACTORY SETTING WILL ASK TO RESET SETTING ONLY AND RESET ALL DATA AND SETTING.CHOOSE THE OPTION OF RESETTING ALL DATA AND SETTING.
  3. IF IT ASKS FOR CODE THEN USE 12345
  4. PRESS O.K.
NOW YOU ARE DONE.
THANKS FOR USING FIXYA
Mar 03, 2011 | Nokia Cell Phones
Master reset code for nokia 7310 supernova
there are two method of doing hard format on most of the nokia devices.
1.manually
now you are done.
2.USING CODE.
always use fixya to fix every thing
Feb 15, 2011 | Nokia 7310 Cellular Phone
I want nokia 3600 slide phone format number
1.MANUALLY
now you are done.
2.USIN
G CODE
DIAL *#73
Feb 15, 2011 | Nokia 3600 slide Cellular Phone
I forgot my nokia 5220 security code,i need it at restor factory setting to restore setting,i had tried even master code but not solved, so as early as possible send me that...
i need it at restor factory setting to restore setting,i had tried even master code but not solved,so as early as possible send me that codeIMEI-356840026724145thank you
Nov 26, 2010 | Nokia 5220 XpressMusic Cellular Phone
How to restore deleted menu icons?
just go on the restore factory setting, and then dial code of restore setting. the code is 12345. and then your phone setting are restored.
Thanks.
Aman.
Mar 22, 2010 | Nokia E63 Cell Phone
How to hard reset a Sony Ericsson K810i ?
your fone default code is 0000, go in setting then slect restore setting or factory setting and enter code 0000.
Jul 25, 2009 | Sony Ericsson K810i Blue Smartphone
Nokia 6103
The DEFAULT SECURITY CODE IS 12345 . BUT IF YOU HAVE CHANGED THAT DEFAULT ONE........THEN,
To get the security code visit this site www.lur.nu/nokia_mastercode/security_code.php
Use that security code to restore factory settings......
HOPE MY INFO SOLVES YOUR PROBLEM......
Thanx for using fixya....
Oct 09, 2008 | Nokia 6103 Cellular Phone
Blue patch
you didn't state how many hours are on the unit, but I'm guessing close to 3,000 hours, that is when most brands have LCD panel failures, due to the heat over time the coating on the lcd panels burns off, the panels start to burn up, and it gets worse with time, and you notice it more when you put a fresh bright lamp in. if it is low hours then you could have a bad lamp, that casts a bad tint, but it sounds like fried LcD panels, a sure way to tell, is put up a white back-ground screen and see if you see discolored "BLOB" in the center of the screen.
keeping the filters clean, and the projector cool is the best way to prevent this.
Nov 09, 2007 | Hitachi PJTX100 Multimedia Projector
Ilco Kaba 101126d41 Lock Combination Logo
191 people viewed this question
Top Ilco Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Ilco Lock and Locksmithing Expert? Answer questions, earn points and help others
