Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Want to change blades on Craftsman 42" mower
Need to get blades off as one is vibrating, but Cannot get blades off as I cannot see how to keep it from spinning when I crank on the nut. I guess I will try and power wash under the deck tomorrow to see if that gives me any clues. I think the loose blade may have ground off the "star" that keeps it in place under the nut, as when I push up on it, I cannot feel it catching on anything, so I may have a more complex problem on that side. I tried getting the blade off on the other side too, but could not stop it from turning, as I need to sharpen the blade. Is there a hole somewhere to jam a screwdriver into to keep it from spinning? What is the trick?
  • 15,935 Answers
Thanks for using FixYa!! A FixYa rating is appreciated for answering your FREE question.
Posted on Jun 20, 2009
I believe that you need a block of wood which will fit into the deck to stop the blade from turning. I use a 1x6 block it fits perfectly. Did you remove the deck? Try www.ehow.com. should have a video that shows you.
Posted on Jun 29, 2009
    Sergeant:
  • 353 Answers
Wrap a rag around blade. one hand on blade. one hand on wrench. at 20 degree apart "V".
pull hands together. best to remove deck.
What would cause a heavy vibration on my craftman riding mower, not caused from the deck, but by the v-drive belt for the tractor. i replaced it and without even putting the mower deck back on the vi
You did not finish the statement about without the blades but if your saying what I thing you are...Ah Oh Sounds like you may have a bent crank..Did you hit something with the blades...take the belt off and start the motor..and Check for wobble of the V drive there should be NONE if it does it could be bent itself or the crank...good luck
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman excessive vibration lawn mowers problems
vibration in a walk behind mower is most always a imbalance in the blade , there lots of things that cause this , from loose blade , to bent blades
remove blade and test with blade balance , there not expensive ive seen them with a sharping stone for less than ten dollars before
pull spark plug before you remove blade 4 safety
Jun 07, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower deck vibrations and sparks.
Hi, you have either a bent blade, bent deck or collapsed bearings in a blade spindle. Hope this helps, regards Phil.
Jul 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 19.5hp 42'' deck lawn tractor with vibration only when the cutting blades are engaged.I have changed the blades but the the tractor still vibrates alittle. when I disengage the blades the...
Check your spindles, especially the shafts in the spindles. If one of them is bent, it'll make the blades vibrate as they spin. You can find replacement shafts and spindles at Partsbuggy.com.
Dec 18, 2010 | Garden
VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Dec 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" Tractor Blade Problem
sounds like either the spindal bearings are shot or maybe the spindal shaft is bent. check for up and down slop at the blades. then turn blades towards each other and check that the heigth lines up. also chec the idler pully to make sure it is not slapping around.
Aug 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Jul 27, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
340 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
