Question about Xante Toner Refill for Ilumina 650 GS Digital Color Press
How can i refil toner on ilumina press - Xante Toner Refill for Ilumina 650 GS Digital Color Press
Magenta Stained product on a Xante Ilumina
i want to ask few question, are you using correct envelopes for this machine or can you use any type, is the weight of paper like is 20lbs
paper, or is it cheap 99 cents paper.
the port where the color ink is spout or ejector port is issue.
call the manufacture customer care center ask for technical services.
go online to the following sites for more help or informations.
www.ask.com/mfg.name/make/model/
/service/manuals/
/operational/manual/
/troubleshooting/guide/
/FAQ/
/customer/service/telephone#/
Oct 06, 2015 | Xante Ilumina 502 GS Digital Color Press...
How to reset drum and toner on ilumina 502?
hi, try this.- power of - unplug from power- press power buton for 1 minute- plug power in and power on- should be reset
Aug 19, 2014 | Xante Office Equipment & Supplies
How i can fix this problem 929:fatal error .
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
May 16, 2014 | Xante Ilumina Digital Color Press Printer
Xante fatal error 929
Feb 11, 2014 | Xante Ilumina Digital Color Press Printer
Why is my toner smearing all over my belt when I print?
what is the life of the belt? try with a used one and see.
Oct 25, 2013 | Xante Ilumina Digital Color Press Printer
Waste toner near full
there is a white gear whre you install the waste toner box, that is connected to the box. see if it's broken - yoy will see the spring that is inside the gear
Sep 20, 2013 | Xante Ilumina Digital Color Press Printer
C9800 fatal error 145
Toner Feed Switch Error. Toner Lock Lever Open Error
145 = Magenta Imaging Drum
Mar 11, 2013 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
Toner disappears!
ok, this issue is not toner related actually. the toner bottles you have removed, I am sure still feel the weight of a nearly full one.
The issue, is most likely, the Image Drum, the toner volume, is actually measured by toner flow resistance by a device within the Image Drum, I can explain it in detail, but will take a page..
toner cartridges, only have a chip transmitter in then, that tell the machine a code when it is first installed into the machine, this resets the toner volume processor only, then the yoner flow resistance inside the Image Drum signals the processor as to how the toner is travelling..
Replace the Drum, and then enjoy using all those almost full toners...
Aug 21, 2008 | Xante Ilumina Digital Color Press Printer
I have installed a new yellow cartrige(original) but the printer does not recognise the cartrige and does not want to do anything.(Error message 150). What can I do?
if this is an Ilumina, try lifting out the whole yellow Image Drum. and make sure all the contacts(both ends) are clean from toner dust etc.(on the drum ends as well as the machine contacts) and re insert and re start....could be the trick..
Jul 23, 2008 | Xante Ilumina Digital Color Press Printer
Xante Toner Refill for Ilumina 650 GS Digital Color Press Logo
13 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
