Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food thawing, Temp and freezing improved, but still running all the time on #2 setting.
  • 2 more comments
  • tkautomed Jun 20, 2009
    temp around 18-20*
  • tkautomed Jun 21, 2009
    Thanks Vic, we removed the panel and yes the evaporator fan is running. And the coil was solid ice. We unpluged it and let it defrost fully. Is there a reason the coil froze or should I have let it defrost for more time when I defrosted it last week, all visable frost was gone on the inside. or is there something wrong causing ice to build up on the coil.
    It was ice and thick frost
    13.7 cu ft Frigidaire upright freezer with automatic defrost
    Model #AFFUI466DWI
    President:
  • 1,136 Answers
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Posted on Jun 20, 2009
  • 2 more comments
  • Victor
    Victor Jun 20, 2009
    OK, You can remove the rear inside panel and see if there is a frost build up on the evaporator. There should only be a film of frost and it should cover the intire evaporator coil. Also notice if the evaporator fan motor is running. Please let me know what you find.
    Vic
  • Victor
    Victor Jun 21, 2009
    If it is solid ice and not frosty, the drain is plugged. If it is frosty, there is one of three defrost parts that has gone bad. I tell my cusomters to let them defrost for 24 hours to be sure all the frost melts. Let me know if it's ice or frost please.
    Vic
  • Victor
    Victor Jun 21, 2009
    ok, because of the ice, make sure the drain hole is unplugged. For the frost, try and located the defrost timer and manually set it into defrost mode. Without the model# I can not say for sure where it is located. Once the timer is in defrost, you might have to remove the rear panel again and see if the defrost heater comes on. If the heater doea not come on, you will need to test the defrost heater an the bi-metal switch. Both of these will need to be tested for continuity.
    Let me know how you do please.
  • Victor
    Victor Jun 21, 2009
    Ok, The defrost timer is located behind the freezer and it is in a box with a hole in it so you can turn the timer with a screw driver. Turn it clockwise.
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Ice in the bottom of freezer
Greetings,
the drain is clogged most likely...remove lower shelves, baskets, remove rear panel if self defrosting.. find the drain hole and use a hair dryer or hot water to defrost ice..once the surface ice is off...you will need to make sure there is no ice in drain tube going down under freezer. use a squeeze bottle with hot water and force it into drain. do this repeatly until water runs free down drain....Bruce Denton
Jan 09, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I need to know the cubic feet of my upright frost free frigidare freezer Model # MFU17F36W6
get a measureing tape measure inside dimensions multiply them together eg: a freezer with an inside dimension of 2' X 2' X 3' would equal 12 cubic feet if want an exact value measure in inches 24" X 24" X 36" = 20736 and divide by 1728 will give you cubic feet cool eh.. where did I get the 1728? (12 X 12 X 12) =1728 converts cubic inches to cubic feet Good Luck let me know when you pour that cement pad for under your shed I tell you how many yards to order
Oct 23, 2009 | Freezers
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Aug 15, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
323 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
