Question about Canon EOS 40D Digital Camera
Canon 40d sd card - Canon EOS 40D Digital Camera
3 Suggested Answers
mvititoe
  • 14 Answers
SOURCE: Canon 40D LCD Wont come on buSY flashes in view finder
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
Posted on Dec 31, 2008
  • 4090 Answers
SOURCE: Canon 40D and 64Gb CF Card
What i find is that the larger the card the slower the write recovery in taking pictures. If you are an action photographer this is a pain as things happen fast . To have the camera take so long to recover from a write leaves you open to losing some excellent shots. So my rule of thumb is use smaller value cards. If you are just a happy shots photographer then this probably doesn't really matter.
Thanks for using Fixya
Posted on Sep 15, 2009
Is there a way to fix my memory card when it says cannot create folder?
The memory card may have the write protect switch on.
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 13, 2013 | Canon EOS 40D Digital Camera
My canon 40D won't read the CF card anymore and says "CF CARD FULL"
check for bent CF pins. make sure there is room on the CF card.
busy is normal
Jun 02, 2012 | Canon EOS 40D Digital Camera
The main PCB is apparently faulty on my 40D , is there a cheap fix for this , or does it have to be done at a Canon recomended repairer? The quote I have recieved is very expensive
PCB???? Printed Circuit Board? Why do you feel the circuit board is at fault?
Did you set an "old" film flash in the hot shoe like a Vivitar 283? if so you fried the board's flash system.
Or does the pop up internal flash unit not pop up?
Did you attempt to install a large capacity SD card?
Did you fail to format a new card?
Are you getting an error code like "Error 99"?
Unless you fed power into the camera from an incorrect outside power source cable to 110 volt wall socket OR used an old film flash which generates up to 300 trigger volts, I would have some doubts of the Circuit Board being "faulty"
May 03, 2011 | Canon EOS 40D Digital Camera
Got Error 99 on my 40D. Have done all the obvious: remove battery, replace battery, check lenses, SD cards. Have talked with several people who tell me it's "common" with 40D. Any assistance you...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks!
Mar 27, 2011 | Canon EOS 40D Digital SLR Camera Digital...
I bought a new memory stick for my canon eos 40d and took it out to download pictures and now the camera won't work, it says format card to camera
You need to format the card in-camera. This is done via the camera menu. The camera needs to format it to it's own file system, you shouldn't format the card in a computer.
Dec 15, 2010 | Canon EOS 40D Digital Camera
My Canon 40d keeps saying' CF card not formatted Format card with this camera'. I tried to do that but it says ' Cannot format Change the CF card. I have 6 cards and I've tried them all with the same...
My 40d keep saying the cf card is not formatted. I used three different cards and it says the same thing. Is it anything I can do to fix this problem.
Nov 29, 2010 | Canon EOS 40D Digital Camera
Sep 15, 2009 | Canon EOS 40D Body Only Digital Camera
Nov 30, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D
go to canon site and upload the new firmware
Aug 05, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
