Question about HP Compaq 2510p Notebook
Internal modem my device does not connect with the internal modem
    Top Expert:
  • HP Master
  • 22,133 Answers
Have you loaded the correct drivers? If yes, it is not uncommon to have the WiFi board fail. They are not costly to replace.
Posted on Apr 22, 2014
Micromax Modem showing "No device"
try uninstalling the micrmax software from your computer and restarts the system. Now run the micromaxinstallaion.exe file in compatible mode
May 08, 2017 | Computers & Internet
ZTE HSDPA USB modem seems to install OK on DELL inspriron 6400 running XP but will not connect to internet and always gives an error message saying 'cannot connect modem is in use or not installed...
Start by checking the status of the modem in device manager, right click my computer and select manage, then on the left side select device manager, on the right side look for anything with ! or ? mark and look for your modem.
Jul 26, 2008 | Computers & Internet
My dimension 3100 is not detecting a modem
Sir,
Respectfully please first check if there is a modem in the desktop PC since the dimension 3100 is not pre-equipped with a modem. you have to attach an internal modem manually on one or more PCI slots on the mother board.
the process is given here....
  • Turn off the computer. Unplug the power cord from the electrical outlet. Disconnect the power cord, attached peripheral devices and any other cables.
  • 2 Locate the cover release latch on top of the computer, near the back. Place the computer on its side, with the removable cover facing upwards. Slide the cover release latch back and lift the removable cover off of the computer. Set the removable cover aside.
  • Locate the PCI and PCI Express slots near the bottom of the system board. Select a slot that corresponds with your internal modem card. Open the card retention door on the back of the computer and remove the filler bracket for the card slot you will be using.
  • 4 Place the internal modem card into the appropriate card slot and press it firmly into place. Close the card retention door. Replace the removable cover and return the computer to an upright position.
  • 5 Connect one end of the telephone cord into the LINE port on your internal modem card; plug the remaining end into a telephone jack. If desired, connect a telephone to the internal modem card via the PHONE port.
  • 6 Reconnect the power cord and all previously disconnected cables. Plug the power cord into an available electrical outlet. Turn on the computer. If any installation software came packaged with the internal modem card, run the program and follow the onscreen directions. Your internal modem is now ready for use.
  • May 06, 2011 | Dell Dimension 3100 PC Desktop
    I just put in a new 56k internal modem and its working but I can only connect at 33.1 kbps
    It probably is not your modem at all. Usually its limited by the computer or ISP you are connecting to, If possible i would try changing the # that you are dialing into and see if you connect at a faster speed. One thing to check is to go to device manager and click on properties on the modem and make sure it is set to max 56K Hope this helps you.
    Jun 22, 2010 | Smartlink All 56K Modems: V.92 PCI Chipset...
    D-Link Modem losing connectivity
    GO TO DEVICE MANAGER AND LOOK FOR YOUR MODEM OR ROUTER SEE IF IT IS WORKING PROPERY.YOU CAN RESET IT BY UNPLUGING THE POWER SOURCE TO YOUR MODEM AND ROUTER FOR TEN SECONDS THEN PLUG BACK IN.
    Nov 30, 2009 | D-Link (DCM-202) Modem
    I've got an Everex 3400+ and when I plug my cable in from my cable modem into the internal modem it's not showing that it's connected. Is there a driver I need to download. can you recommend a network...
    Please dont connect a cable modem to an internal modem.
    These are not the same types of device.
    you need to connect from the cable modem to the ETHERNET port.
    They look similar but ethernet is slightly larger.
    Dont use a telephone cord for the ethernet connection it is the wrong one.
    Sep 14, 2009 | Everex GA3400 Refurbished AMD Desktop...
    I cannot connect my L350 series laptop to the internet. I am using a dial up connection. Problem???
    you must have a modem to connect to internet. if you are using an external modem check whether it is working. If you are using internal modem check whether you have installed the drivers and working properly. You can find modem devices at device manager(control panel -> system -> device manager)
    Sep 02, 2009 | Computers & Internet
    Internet connection through Internal modem in Laptop
    Two solutions:
    First for the more experienced:
    find the modem on the underside of the laptop unscrew/ re-seat the modem, test, if it works great, if it doesn't try inserting foam, or paper between the modem and the "black case"... if you cant find the modem locate the manual for the laptop.
    second (and possiblely the best)
    Disable the onboard modem and replace it with a USB one
    Aug 28, 2008 | Compaq Presario 700 470024-192 Notebook
    HP dv1000 laptop and internal wireless modem
    Although you have internal wireless, you are capable of attaching an external wireless device. For example, you could attached a D-Link WUA-1340 USB Wireless G adapter (http://www.dlink.com/products/?sec=0&pid=477), or, if you have a PCI port, you can use a Linksys WPC300N Wireless-N Notebook adapter (http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1144763513196&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1319686869B07). Either device with any brand will work just like your internal wireless. In fact, because you chose to use an external device, you may get a better wireless signal. Because internal wireless devices are inside the computer, it is more difficult to received a signal than with an external device.
    Apr 20, 2008 | HP Pavilion dv1000 Notebook
    How do I connect my cable/DSL line to this device?
    The 3Com® OfficeConnect® Cable/DSL Gateway does not have an internal cable or DSL modem. The gateway router is designed to connect to the Ethernet output from your cable or DSL modem. An Ethernet cable is supplied with the product for this purpose.
    Feb 16, 2006 | 3Com (3CR856-95-UK) Firewall
    HP Compaq 2510p Notebook Logo
    20 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
