Question about Olympus VR310 Digital Camera
Olympus vr 310 no autofocus
Autofocus on my camera suddenly stopped working. seems to be stuck in fixed focus for macro shooting? tried resetting, memory formatting, removing batteries etc all to no effect. any suggestions please?
jackboy
  • 2985 Answers
SOURCE: Autofocus has stopped working
Olympus web site for a repair or replace option.
Posted on Aug 04, 2007
  • 919 Answers
SOURCE: Olympus 1010 lens stuck out. Won't shoot either
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $87.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Mar 30, 2009
SOURCE: My Olympus FE-310 has battery problems!
I have the same model and I sort of took a page out of Solution #2.
I don't have electronic technician experience so I took one main insight: The Poor Design of the Conduction in the bottom cover.
Here's what I did: I took some Copper Wire (mine came from the wire you use to hang paintings) and some Aluminum Foil.
Next I wrapped the Copper Wire with the Foil. The piece was roughly slightly bigger than 1/2 of a Postage Stamp.
Then I inserted this metal square over the batteries and closed the cover.
I found that I could take more shots without the camera saying Battery Empty.
See if this works. So far it's touchy but it's been taking more photos than before.
Posted on Oct 28, 2009
  • 11967 Answers
SOURCE: downloaded firmware update for olympus
It's always dangerous to download a firmware update because if you don't follow the directions perfectly, you could end up with a "brick" instead of a camera. Review what you did and compare that to what the directions said. Also, when you were done, (if you connected the camera to the computer) did you remember to use the "safely remove hardware" function?
Posted on Sep 04, 2011
Rider On Way
  • 1679 Answers
SOURCE: Olympus vr 310 camera on/off button stuck even
I cannot say if you can fix it, however you can give it a try. This requires a few technical troubleshooting related to hardware.
If your Camera is In-Warranty, Call the camera support people and check if they can do something about your device ?
I Hope the steps below should be helpful in fixing your camera issue.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on Oct 15, 2011
I would like an instruction manual please.
The user manuals coming with lenses most of the time have little information about how to use them. The lens will have a MF and AF and perhaps a VR switch. If you want to learn more about macro photography, check this site from Ken Rockwell, where he is explaining how to do so with a Nikon camera.
Be aware the macro lenses are designed to focus close to the camera and will have the sharpest pictures close to the camera. I would not say you can't use a micro as a tele, but the results with a normal 105 could be better.
Still I think you have a great lens with your Sigma.
How to Shoot Macro
Mar 31, 2015 | Sigma Telephoto 105mm f/2.8 EX Macro...
Aoutofocus stopped working
Please remove the battery and and then insert it again and test to automatically reset the setting.
melnavz
Oct 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Appears to take piccies ok, but when viewed back the bottom right of the picture (probably at least 25% of overall) is always badly out of focus and blurred. Seems ok in Macro mode but not in normal ....
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 07, 2011 | Canon IXUS 860 IS Digital Camera
I've got a DSC-S700 that I can't get to take clear pictures, I've tried all different settings and even automatic, still get blurry pictures, it was formated when first purchased, will formatting it again...
The memory card formatting is not the problem.
There may be a fault with the camera, in which case you should return it under warranty if you can, but before you go there, have you put the camera into Macro mode? This is an extreme close up mode in which the camera will only focus on objects few inches from the lens, even using autofocus. The icon for Macro mode is a little flower.
Nov 27, 2010 | Cameras
Autofocus stopped working
I fix these all the time for this problem, The focus motor is bad, Tony
May 23, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Lens will not open up all the way
Is the maximum available aperture dependent on the focus distance? Many macro/micro lenses "dim" slightly as you focus in close.
See if you get 2.8 focused at infinity.
May 22, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
If you just purchased the lens I would take it back sounds like the lens is jarred and defective should still be on warranty
Jan 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Canon S5 IS. I am having problems with Macro shooting. As I look through view finder, object seems in focus, but when I press focus lock button (halfway) the image jumps out of focus.
Dear Stefan:
Barring a malfunction with your len's autofocusing mechanism, the problem that you're experiencing is likely due to the limitations of the camera's focusing / zoom range in Macro mode.
You didn't say what ranges you were shooting from but basically, in order to get proper focus, you must first make sure you're within the proper lens to subject distance for the macro mode that you've chosen.
There are two macro modeson the S5, Macro and Super Macro. Macro shooting is done only within the ranges of 3.9 inches to 1.6 feet from your subject. SuperMacro mode (which is entered into by simply pressing the Macro button for one second) will only focus within the ranges of 0 inches to 3.9 inches. So if you are in either of these modes and stray from their focusing ranges, your camera won't focus properly.
Another issue that you may be dealing with is the very limited zoom range in Macro/Super Macro Modes. The zoom is basically meant to be set toward the maximum wide angle end of the zoom range. There is a yellow indicator bar below the Zoom Bar in the viewfinder that indicates the Out-Of-Zoom range in which the zoom basically can't be used. As you may see, only the first 10% or so of the zoom range is useable.
It might be that you could possibly be wavering in and out of the two macro mode focusing ranges and/or zooming into the Out-Of-Range zone during your session. Either can cause a similar effect such as you are describing. It's hard to say without actually being there.
To test this out I would simply set my camera on a tripod or other stand at a known fixed distance from the subject, set the camera to the macro mode indicated by that distance (either MACRO or SUPERMACRO), zoom out to the widest focal length and take the shot to see if it is clear or not.
If so, your camera probably has no problem. If it is still not focusing properly you might want to send it into the service center for a diagnostic. There is no charge to diagnose a problem with your camera and if nothing is found to be wrong you will only be out of the shipping charges spent to send the camera in to the service center. If a repair is needed, it can be done at that time.
Hope this helps you.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon Cameras
Olympus VR310 Digital Camera Logo
66 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
